set A-axis to 0.0
01 Jun 2015 14:40 #59297
by jornbyte
set A-axis to 0.0 was created by jornbyte
Hello
I want the A-axis to 0.00 provide without it rotates.
Is that a MIDI commando possible?
01 Jun 2015 19:41 #59304
by BigJohnT
Replied by BigJohnT on topic set A-axis to 0.0
Have you tried to just re-home the axis... that seems to work in the sim.
JT
JT
01 Jun 2015 23:01 - 01 Jun 2015 23:02 #59312
by jornbyte
Replied by jornbyte on topic set A-axis to 0.0
Hello John
the axis rotates, which I want to avoid.
I use a 3D printer LinuxCNC. After a job XYZ be reduced to zero.
The A axis retains its value. When I start a new job it rotates to zero and used filament that should not be. Therefore I'm looking for a solution.
excuse my english I'm from Germany
Jornbyte
Jornbyte
Last edit: 01 Jun 2015 23:02 by jornbyte.
01 Jun 2015 23:52 #59317
by alan_3301
Replied by alan_3301 on topic set A-axis to 0.0
Does the extruder axis have a homing routine? I wouldn't think so.
It should just reset it to 0 without moving.
If you are using the axis GUI click the menu item "machine" then "homing" then "home A axis"
02 Jun 2015 00:44 #59318
by jornbyte
Hello alan_3301
the extruder has no reference switch is why he turns to it again is zero.
02 Jun 2015 23:09 #59349
by ArcEye
Replied by ArcEye on topic set A-axis to 0.0
If you set the HOME_SEARCH_VEL and HOME_LATCH_VEL etc to 0, it will home without movement and zero the DRO
www.linuxcnc.org/docs/devel/html/config/....html#_configuration
02 Jun 2015 23:26 #59352
Replied by andypugh on topic set A-axis to 0.0
Alternatively G10 L20 P0 A0
07 Jun 2015 20:20 #59574
by jornbyte
Hello
I've now tested, the axis rotates.
Is there another solution?
Jornbyte
Jornbyte
07 Jun 2015 20:33 #59575
by ArcEye
Neither options should cause movement, you will need to attach your ini file.
Hello
21 Oct 2015 02:41 #64016
by jornbyte
Hi
I've found it ... G92 A0 is the command
Time to create page: 0.159 seconds
