Tool offset
05 Jun 2015 06:36 #59449
by ReinaldoP
Tool offset was created by ReinaldoP
I'm trying to get Txxyy working like our other lathes in our shop. I'm running linuxcnc 2.6.7 and using gmoccapy. What would be the recommended procedure?
I already read all the posts on this topic and I'm confused should I do the patch? remap? change .ini settings? create new remaps?
05 Jun 2015 06:41 #59450
I would suggest remap. You ought to be able to just copy the relevant files from the sim->axis->lathe-fanucy config.
(run that config first from the chooser, see if it acts like you expect)
Replied by andypugh on topic Tool offset
The following user(s) said Thank You: ReinaldoP
09 Jun 2015 23:00 #59656
by ReinaldoP
Replied by ReinaldoP on topic Tool offset
Thanks, it worked. Ran the sim first, then used the .ini file from the sim to figure out where all the files needed to go, copied them to the new destinations. Loaded my configurations with the new files and paths fixed and it worked.
11 Jun 2015 23:47 #59712
by ReinaldoP
While using this remap I noticed the offsets are not being applied the first time I command a Txxyy. It takes two commands instead of one, first one changes the tool and applies Txx offset but the actual wear offset is not apllied until I rerun Txxyy a second time. So basically it only applies the wear offset if the tool is already there. Any ideas on what may be causing this?
12 Jun 2015 03:54 #59729
Hmm, no, not really. :-/
Can you raise that as a bug on the bug tracker assigned to me? (The bug tracker is in the "Community" section,
12 Jun 2015 05:28 #59734
by ReinaldoP
Just did, I'm on 2.6.7 but I set milestone as future-release by mistake.
13 Jun 2015 08:21 #59773
Replied by cmorley on topic Tool offset
try adding m6 after the '0100 endif' in the toolchange.ncg
I found I had to do this in my python script.
Chris M
Chris M
01 Jul 2015 23:45 #60315
by ReinaldoP
I tried that but still got the same behavior.
Chris M
02 Jul 2015 05:08 #60318
did you add it or change it.
In my python script I had to have it twice:
def index_fanuc_lathe_tool(self,**words):
# only run this if we are really moving the machine
# skip this if running task for the screen
if not self.task:
return INTERP_OK
try:
# check there is a tool number from the Gcode
cblock = self.blocks[self.remap_level]
if not cblock.t_flag:
self.set_errormsg("T requires a tool number")
return INTERP_ERROR
tool_raw = int(cblock.t_number)
# If it's less then 100 someone forgot to add the wear #, so we added it automatically
# separate out tool number (tool) and wear number (wear), add 10000 to wear number
if tool_raw <100:
tool_raw=tool_raw*100
tool = int(tool_raw/100)
wear = 10000 + tool_raw % 100
# uncomment for debugging
# print'***tool#',cblock.t_number,'toolraw:',tool_raw,'tool split:',tool,'wear split',wear
# set HAL pins
self.h["tool-number"] = cblock.t_number
self.h["tool-wear-number"] = wear
# check for tool number entry in tool file
(status, pocket) = self.find_tool_pocket(tool)
if status != INTERP_OK:
self.set_errormsg("T%d: tool entry not found" % (tool))
return status
# if there is a wear number, check for it in the tool file
# For wear offset 00, we dont require a tool 10000 entry in the tool file - so we will skip this check
if wear>10000:
(status, pocket) = self.find_tool_pocket(wear)
self.set_errormsg("T%d: wear entry not found" % (wear))
return status
# index tool immediately to tool number
# immediately add tool offset
self.selected_tool = self.selected_pocket = tool
emccanon.SELECT_POCKET(self.selected_pocket, self.selected_tool)
self.execute("m6")
self.execute("g43 h%d"% tool)
# record the x and z offsets of the current tool
x1= float(self.tool_offset.x)
z1= float(self.tool_offset.z)
# if the wear offset is specified, immediately add it's offset
if wear>10000:
self.execute("g43.2 h%d"% wear)
# Not sure why but must call this again to resynch, other wise
# ;py,print self.tool_table[0].toolno (in mdi) will always be one tool behind
self.execute("m6")
# calculate wear offset and set HAL pins
self.h["tool-offset-x"] = x1
self.h["tool-offset-z"] = z1
self.h["tool-wear-offset-x"] = (float(self.tool_offset.x) -x1)
self.h["tool-wear-offset-z"] = (float(self.tool_offset.z) -z1)
# all good
return INTERP_OK
except Exception, e:
self.set_errormsg("T%d index_fanuc_lathe_tool: %s" % (int(words['t']), e))
return INTERP_ERROR
02 Jul 2015 22:43 #60348
by ReinaldoP
What .py file is that? stdglue.py or the remap.py? its totally different from what I have. My remap.py only gets the tool number and passes over to toolchange.ngc
Time to create page: 0.234 seconds
