spindle counts
- cabocozika
28 Aug 2015 22:01 #61868
by cabocozika
spindle counts was created by cabocozika
Hi m66 counts spindle turns?
28 Aug 2015 22:31 #61869
by ArcEye
Replied by ArcEye on topic spindle counts
No
M66 waits for a single input
www.linuxcnc.org/docs/devel/html/gcode/m...l#_m66_wait_on_input
encoder.N.counts will count spindle turns if you have an Z index attached
www.linuxcnc.org/docs/devel/html/man/man9/encoder.9.html
- cabocozika
29 Aug 2015 00:05 #61870
by cabocozika
Replied by cabocozika on topic spindle counts
hi, ArcEye
How i do counters spindle turns and disable it?
ex: spindle 300rpm and do 300 turns and disable?
29 Aug 2015 13:18 #61882
by ArcEye
You need to explain what you are trying to do overall.
Past experience of answering narrowly framed questions like this with no other information, is that the answers you get will not be the right ones, or not the best.
If you say what your problem is, rather than ask how to achieve what you have predetermined as the solution, you may well find someone has done it already.
Time to create page: 0.095 seconds
