Incremental Offset from G54
22 Sep 2015 19:29 #62852
by nooob
Incremental Offset from G54 was created by nooob
Hi guys,
is it possible to make an incremental Offset from G54?
Lets say i want to move G54 2mm in Z+ is there any code for that?
in other controls for example Heidenhain you say
u can read about it here on Page 235: >>CLICK ME<<
greetings nooob
CYCLE DEF 7.0 DATUM SHIFT
CYCLE DEF 7.1 Z+1
greetings nooob
- Thank you received: 1369
22 Sep 2015 22:38 #62859
Replied by Todd Zuercher on topic Incremental Offset from G54
Sort of. There isn't a specific incremental shift command. But you can achieve the same effect with the G10L2 command combined with the coordinated system parameter number for the axis you want to shift. such as this
This would shift your Z G54 2mm (if you were in G21 mode).
I am not sure if this would work but it might achieve the same effect
but I know the first example works see here for the parameter numbers for other axis and coordinate systems
linuxcnc.org/docs/2.6/html/gcode/overvie...umbered_parameters_a
G10 L2 P1 Z[#5223 + 2.0]
#5223=[#5223 + 2.0]
22 Sep 2015 22:55 - 22 Sep 2015 22:59 #62862
I quick tested it and the second example and while it does change the value of the stored parameter, it doesn't update the DRO and my not work in a program by itself. but if it is followed with G10 L2 P1. The DRO updates to the new value stored int the parameters.
so it seems thatis equivalent to
so it seems that
#5221=[#5221+1]
G10 L2 P1
G10 L2 P1 X[#5221 + 1]
Last edit: 22 Sep 2015 22:59 by Todd Zuercher.
22 Sep 2015 23:18 #62865
Does it actually update the axis offsets, though? I wouldn't necessarily expect it to. I think that the numbered parameters are one-way mirrors of the internal offset numbers, but they may also be what Axis is using to calculate DRO values. If that is the case then there might be a discrepancy between the DRO and actual machine position.
I think that the first option (computed G10) is the most reliable solution.
Replied by andypugh on topic Incremental Offset from G54
The following user(s) said Thank You: nooob
23 Sep 2015 00:13 #62866
by nooob
Replied by nooob on topic Incremental Offset from G54
Thanks for the fast answers
i will try it tomorrow on my machine.
Im wondering that no one is missing this feature expect me until now, are u guys using a different method?
i'll guess
#5221 is X-Axis
#5222 is Y-Axis
#5223 is Z-Axis
right?
i'll guess
#5221 is X-Axis
#5222 is Y-Axis
#5223 is Z-Axis
right?
23 Sep 2015 01:44 #62869
Yes that is right.
I actually have a series of pyvcp buttons set up (laid out like a jog keypad) for incrementally jogging the G54 offsets on one machine.
+Z+Y+W
-X ? +X
-Z -Y -W
these are linked a bunch of halui commands of G10L2P1[#522n +?]
I'm guessing most people just use the tool touch off widget in axis.
It might be a worthwhile endeavor to try to use remap to make the G- code you need (perhaps a G10L2.1 for incremental adjustments)
+Z+Y+W
-X ? +X
-Z -Y -W
23 Sep 2015 14:23 #62878
by nooob
i tested it, it works great!
thank u Todd and andy.
I think i will try to make me an pyvcp for this
Greetings from Germany
Time to create page: 0.189 seconds
