FreeCAD g-code generator?
21 Jan 2016 15:30 #68884
by mstrick96
FreeCAD g-code generator? was created by mstrick96
Has anyone worked with the Path Workbench in FreeCAD for generating g-code?
The developer says it is in early stages,mbut it looks like it has some interesting features already. Especially for making simple parts.
What do you think?
What do you think?
23 Jan 2016 10:19 #68957
by emcPT
Replied by emcPT on topic FreeCAD g-code generator?
Recently I found ECAM:
ecam.altervista.org/
The best free CAM that I know, and I tested it several times both for milling and lathe. Development is active and the postprocessor can be changed to suit for example linuxcnc.
The following user(s) said Thank You: mstrick96
23 Jan 2016 20:47 #68998
by BigJohnT
Replied by BigJohnT on topic FreeCAD g-code generator?
For a lathe I do all that and more with ngcgui.
JT
JT
23 Jan 2016 22:22 - 23 Jan 2016 22:25 #69006
by mstrick96
Replied by mstrick96 on topic FreeCAD g-code generator?
Thanks. Good info.
I'm building a longbed lathe and am thinking of adding a NC machining head to it later. Am most interested in building an NC router for woodworking and setting up a CAD/CAM/CAE workstation to do the design and control for both.
I like the looks of FreeCAD and am running it on a Debian 8.2 workstation with LinuxCNC. Am figuring out how to replace the Jessie kernel with a recent RT kernel and will then be set if the g-code in FreeCAD works well enough. If it doesn't work well, I'l try your suggestions.
Lots to learn!! Too many hobbies and not enough time!
Last edit: 23 Jan 2016 22:25 by mstrick96.
23 Jan 2016 23:08 #69007
by BigJohnT
Well ngcgui is part of Linuxcnc so it is seamless and fast to program any part. So that takes a step or three out of the process.
JT
JT
24 Jan 2016 01:59 #69013
by mstrick96
Great! Looks like I have two options built in, then.
Thanks!
Thanks!
Time to create page: 0.108 seconds
