G93 vs G94
14 Jun 2016 21:46 - 15 Jun 2016 21:04 #76028 by subnoize
G93 vs G94 was created by subnoize
Hello Everyone!
Forgive me, I've been out of the loop for a while. I turned to 3D printing for a while but I need to get back cutting metal again.
The maker of my CAM software promised he would implement G93 (inverse timing) and now 3 years have passed and no G93. If I remember correctly LinuxCNC wants the mode to be G93 for using angular axis with linear axis motion.
Is this still correct? Am I still begging access from my friends with AutoCAD to produce my G93 compatible code for my homemade 4 axis machine?
Thanks for the help, sorry for the stupid questions...
--jb
B)
Last edit: 15 Jun 2016 21:04 by subnoize. Reason: Political Correctness ;-)
14 Jun 2016 22:20 - 14 Jun 2016 22:22 #76030 by BigJohnT
Replied by BigJohnT on topic G93 vs G94
Yes we have G93, G94, and G95. When combining linear and rotary axis move G93 is preferred.
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g93-g94-g95
JT
Last edit: 14 Jun 2016 22:22 by BigJohnT.
15 Jun 2016 00:43 #76035 by subnoize
Replied by subnoize on topic G93 vs G94
Thanks for the info. Just a real quick follow up and you seem to be the guy leading the charge here, what is a good affordable 4 axis CAM package? I hate having expensive equipment not being used.
15 Jun 2016 10:43 - 15 Jun 2016 10:43 #76050 by BigJohnT
We are all volunteers here, I just try and help where I can.
Seems like "good", "affordable", and "CAM" don't fit in the same sentence. For my business I use SolidWorks and OneCNC. OneCNC is a bit clunky but my version is a few years old. I refused to upgrade when I found out some of my pet peeves were not fixed. Also note that I'm only using the 3 axis version of OneCNC so I don't really feel qualified to answer the question.
JT
mesaus.com/
Last edit: 15 Jun 2016 10:43 by BigJohnT.
15 Jun 2016 15:25 #76091 by andypugh
Replied by andypugh on topic G93 vs G94
Fusion360 has 3+2 Axis. I can't work out how to find the pricing for the 3+2, though.
It's a free download (Windows and Mac only). Might be worth a look.
15 Jun 2016 21:43 #76123 by subnoize
Hmmm! Let me investigate Fusion360. I use it a lot for 3D printing, hadn't even looked at anything else. I use Rhino3D so I skip everything except squirting out g-code for my printer. If it were a snake it might have taken my head off!
