G10 L2
04 Oct 2016 20:56 #81232 by stiles
G10 L2 was created by stiles
Why does linuxcnc say "Being in incremental distance mode (G91) has no effect on G10 L2". I looked though the NIST RS274NGC documentation and there is no exception for G10 L2. There is an exception for G92. G10 L2 respects G91 on the industry controls I've tested it on.
It make G10 L2 half as functional. And on top of that this behavior has filtered down into other open source machine control projects.
05 Oct 2016 13:26 #81247 by Todd Zuercher
Replied by Todd Zuercher on topic G10 L2
As a work around I have used parameters #5221-5390 linuxcnc.org/docs/2.7/html/gcode/overview.html#gcode:parameters to make an incremental shift in a work coordinate system.
Like this
G10L2P1X[#5220+1]
to shift the G54 X+1.
06 Oct 2016 22:47 #81317 by stiles
Replied by stiles on topic G10 L2
That's a pretty slick workaround. Thanks for that.
Unfortunately the way I ran into this issue is trying to help someone with smoothieware. It's a 3d printer controller, and they have used EMC2/linuxcnc as a model to implement work coordinates. Their "documentation" on work coordinates is a link you linuxcnc's docs. I'm pretty sure they don't have parameters in the traditional cnc fashion, so that workaround won't work very well. GRBL also has implemented the same g10 l2 behavior.
Does anybody disagree with me that RS274NGC makes no exceptions for G10 L2 to explicitly ignore incremental mode?
Here is how I read it:
3.5.17 Set Distance Mode — G90 and G91
Interpretation of RS274/NGC code can be in one of two distance modes: absolute or incremental.
To go into absolute distance mode, program G90. In absolute distance mode, axis numbers (X, Y,
Z, A, B, C) usually represent positions in terms of the currently active coordinate system. Any
exceptions to that rule are described explicitly in this Section 3.5.
To go into incremental distance mode, program G91. In incremental distance mode, axis numbers
(X, Y, Z, A, B, C) usually represent increments from the current values of the numbers.
I and J numbers always represent increments, regardless of the distance mode setting. K numbers
represent increments in all but one usage (see Section 3.5.16.8), where the meaning changes with
distance mode.
Ok so any exceptions to this modal has to be explicitly stated somewhere in section 3.5. And in section 3.5.17 only the polar arguments are mentioned. Nothing about G10 L2.
So on to the 3.5 over view section mentions no exception to G10 L2.
Section 3.5.5, nope nothing there.
And that's all that is relevant in section 3.5.
What gives with this? As far as I can tell the linuxcnc implementation is not complaint to the standard. What's worse is embedded opensource projects are copying this gimped behavior and think they are somehow doing a good thing.
Link 1
and
Link 2
07 Oct 2016 01:31 #81319 by Todd Zuercher
You may get a better response if you asked your question to a different audience, Try emailing the Developer e-mail list.
lists.sourceforge.net/lists/listinfo/emc-developers
Time to create page: 0.071 seconds
