Reading value of pin in g code
21 Mar 2017 09:57 - 21 Mar 2017 09:59 #89991
by Radek
Reading value of pin in g code was created by Radek
Hi, I want to make if loop and don't know how to write it properly. The task is: if state of coil1 (in classicladder) is 1 then make something. Coil1 is assigned to pin P01.
I tried with:or simple
I got this error:
I tried with:
o100 if [M66 P01 L3 Q999999]
o100 endif
o100 if [P01 = 1](funny creating ;) )
I got this error:
Unknown word where unary operation could be
Last edit: 21 Mar 2017 09:59 by Radek.
23 Mar 2017 15:28 #90122
Replied by andypugh on topic Reading value of pin in g code
There are a number of issues here.
Firstly, to check for equality in G-code you have to use "EQ"
O100 IF [#124 EQ 100]
Do Stuff
O100 ENDIF
linuxcnc.org/docs/2.7/html/gcode/overvie...ode:binary-operators
It is possible to read HAL pins in G-code, but the feature needs to be turned-on.
linuxcnc.org/docs/2.7/html/remap/remap.h...i_file_configuration
I wouldn't recommend doing that in this case, though. The problem is that the values are read at preview-time, not at run-time. This could cause unexpected results.
Much better to "net" the classicladder pin to one of the G-code digital input pins and use M66 to read it.
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m66
Do Stuff
O100 ENDIF
24 Mar 2017 07:51 - 24 Mar 2017 08:33 #90173
by Radek
Replied by Radek on topic Reading value of pin in g code
I knew this comands, but i can't use it properly. While loop is working well.
My unfortunately bad ideas ....
also try with GOTO.. here is one of my bad codes..and there is an error:
o100 if [M66 P1 L3 Q99999999]
#1 = M66 P1 L3 Q99999999
o100 if [#1 EQ 1]
M66 P01 L3 Q99999999 N100 GOTO 110
M66 P02 L3 Q99999999 N120 GOTO 130
M66 P03 L3 Q99999999 N140 GOTO 150
bad character n used
Last edit: 24 Mar 2017 08:33 by Radek.
24 Mar 2017 09:05 #90177
The key is the phrase "The current value of the input is stored in parameter #5399"
Though normally you don't need to check the value as you use it in a "wait for state" mode and just need to check for timeout.
M66 P1 L0
o100 if [#5399 EQ 1]
The following user(s) said Thank You: Radek
24 Mar 2017 09:28 - 24 Mar 2017 11:54 #90179
by Radek
Ok, but now i want to back to 1st line of programme. What command should i use? GOTO ?
Ok... shit happens.. it's not working
M66 P11 L0
Do stuff
o100 endif
M66 P12 L0
o110 if [#5399 EQ 1]
Do stuff
o110 endif
M66 P13 L0
o120 if [#5399 EQ 1]
Do stuff
o120 endif
Last edit: 24 Mar 2017 11:54 by Radek.
24 Mar 2017 13:08 #90201
Do you want it to run for ever?
There is no GOTO in G-code:
linuxcnc.org/docs/2.7/html/gcode/o-code.html
O500 WHILE [1 EQ 1]
Do Stuff
O500 ENDWHILE
24 Mar 2017 13:12 #90204
by Radek
I got while loop, but i need also if but it doesn't work.. are there any mistakes in my code ?
24 Mar 2017 13:16 #90206
Well, the command "Do Stuff" if it is literally in the code won't help.
By default there are only 4 digital input pins, so your P11, P12, P13 are likely to cause trouble.
24 Mar 2017 13:30 #90209
by Radek
this is my code... While is working properly, but if not. Why? I want also to back to the 1st line of programme after endif.
24 Mar 2017 14:03 #90210
What error message do you get?
Time to create page: 0.099 seconds
