Enter Numbered Parameter during pouse
27 Apr 2017 12:32 #92195
by tommy
Enter Numbered Parameter during pouse was created by tommy
Is there a way to prompt operator to enter parameter #5410? The idea is to let operator enter tool diameter during (manual) tool change when machine waits operator to change tool.
Tool change is done by subroutine g-code.
- Thank you received: 1369
27 Apr 2017 14:02 #92209
Replied by Todd Zuercher on topic Enter Numbered Parameter during pouse
The answer is it can be done. How comfortable are you with programing your own little popup window?
There is no ready made way to do it.
Here is one way:
forum.linuxcnc.org/38-general-linuxcnc-q...-a-variable?start=10
In this example a custom Mcode (M131) opens a TCL pop up window where the user can input a value.
That value is given to the hal pin "motion.analog-in-00", then in your Gcode you can use M66 E0 L0 to set that value to #5399, you can then use that in your g-code to set the value to #5410.
You could also do it with python, possibly reading/writing the parameter value directly. (I've never done it myself and the above example is the first thing I found in a search. tested and works.)
Here is one way:
28 Apr 2017 12:36 #92259
Replied by andypugh on topic Enter Numbered Parameter during pouse
I have a strong suspicion that #5410 is read-only, or at least that setting it in G-cod won't affect the system's opinion of tool diameter.
In G-code you would use G10 L1, G10 L10 or G10 L11 to set the tool diameter.
In python code you can do it through the tool_offset command:
linuxcnc.org/docs/2.7/html/config/python-interface.html
Time to create page: 0.059 seconds
