Bore thread milling cutters G-code ?
- Weiler810T
- Topic Author
- User is blocked
- Thank you received: 5
15 Aug 2017 12:35 #97501
by Weiler810T
Bore thread milling cutters G-code ? was created by Weiler810T
Hello
Is it possible to create a G-code for these drilling thread milling cutters?
Bore thread milling cutters are tools which can use thread milling to produce a tapping drill hole, 90° counterbore and thread in a single operation.
17 Aug 2017 12:45 #97619
Replied by andypugh on topic Bore thread milling cutters G-code ?
Yes. Spiral milling is a simple G2 or G3 move with a Z change.
(It can be multi-turn by adding a P but I don't think that thread-milling requires that)
The following user(s) said Thank You: Weiler810T
