Need sample G-code with G33.1
31 Aug 2017 17:47 #98306
by tecno
Need sample G-code with G33.1 was created by tecno
Can anybody help me with sample code for say M16x2 20mm deep.
Need this so I can get functional PP and then produce tapped holes in upcoming tests.
Cheers
Bengt
Cheers
Bengt
31 Aug 2017 18:07 #98307
Replied by andypugh on topic Need sample G-code with G33.1
Assuming that the tool is touched-off with the tap at the top surface for Z = 0, and if you want the hole at (10,10)
M3 S100 ; start the spindle
G0 X10 Y10 Z1 ; move to the start position and height.
G33.1 Z-20 K2
You can put the X and Y on the G33.1 line, but I prefer not to.
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g33.1
G33.1 Z-20 K2
The following user(s) said Thank You: tecno
31 Aug 2017 18:13 #98308
by tecno
Replied by tecno on topic Need sample G-code with G33.1
Thank you Andy,
will ask my friends at Dolphin Partmaster to fix the PP for me.
Time to create page: 0.065 seconds
