[Solved] G5 G5.2 parametric
04 Sep 2017 14:35 - 05 Sep 2017 08:34 #98478
by bkt
[Solved] G5 G5.2 parametric was created by bkt
But is possible using G5 or G5.2 with parameter?
Continuosly receive these error: Failed inizialize Circle9 ....
Giorgio
Giorgio
Last edit: 05 Sep 2017 08:34 by bkt.
04 Sep 2017 15:07 #98484
Replied by andypugh on topic G5 G5.2 parametric
G-code?
04 Sep 2017 17:58 #98501
by bkt
Replied by bkt on topic G5 G5.2 parametric
#29 =0
#<_startx> = -500
#<_starty> = -300
o110 while[#29 LT 5]
#<_myvar1startx> = [#<_startx> + [93*#29]]
#<_myvar1startx> = [#<_starty> + [58*#29]]
G0 X#<_myvar1startx> Y#<_myvar1starty>
F#<_myfeed> (fixed)
G5.2 P5 X#<_myvar1startx> Y#<_myvar1starty> L3
X[#<_myvar1startx> + 200] Y[#<_myvar1starty> +100] P5
X[#<_myvar1startx> +300] Y[#<_myvar1starty> +150] P5
X#<_myvar1endx> Y#<_myvar1endy> P5
G5.3
#29 = [#29 +1]
o110 endwhile
04 Sep 2017 20:31 #98506
Having modified your code to include the missing variables, it works.
So I suspect that the problem might be the values in those missing variables. Maybe you are creating a zero-radius circle or something like that?
The following user(s) said Thank You: bkt
05 Sep 2017 05:57 - 05 Sep 2017 08:32 #98517
by bkt
sorry, what means for
not see missing variables in that piece of gcode .... you means these, or i have missing other var?
These is right for you? because my code work whitout error in prewiew on axis, but when try to run I've got the error.
Or maybe the nurbs must be a closed line?
giorgio
G21
#29 =0
#<_startx> = -500
#<_starty> = -300
#<_myvar1startx> = 0
#<_myvar1starty> = 0
#<_myfeed> = 20000
#<_myvar1endx> = 800
#<_myvar1endy> = 1000
G0 X#<_startx> Y#<_starty>
#<_myvar1starty> = [#<_starty> + [58*#29]]
G0 X[#<_myvar1startx>-5] Y[#<_myvar1starty>-5]
F#<_myfeed> (fixed)
G5.3
#29 = [#29 +1]
o110 endwhile
M30
giorgio
Last edit: 05 Sep 2017 08:32 by bkt.
05 Sep 2017 08:33 #98518
by bkt
ok ... I've understand the problem ...
Maybe you are creating a zero-radius circle or something like that?G0 X[#<_myvar1startx>-5] Y[#<_myvar1starty>-5]
Time to create page: 0.073 seconds
