M function during move
- TheRoslyak
- Topic Author
- Thank you received: 30
02 Dec 2020 08:12 #190850
by TheRoslyak
M function during move was created by TheRoslyak
Tell me how to implement the function while driving? It is desirable that it be recorded from the time or distance parameter to the end point.
02 Dec 2020 08:33 #190851
Replied by Aciera on topic M function during move
Hm, is this example taken from a document? If so can you provide a link to it?
- TheRoslyak
- Topic Author
02 Dec 2020 08:35 - 02 Dec 2020 08:39 #190852
by TheRoslyak
Replied by TheRoslyak on topic M function during move
No. I painted myself in Adobe Illustrator
Last edit: 02 Dec 2020 08:39 by TheRoslyak.
02 Dec 2020 08:41 - 02 Dec 2020 08:44 #190853
I see. I don't think you will get this done with standard gcode.
Maybe with a python remap?
linuxcnc.org/docs/html/remap/remap.html#...ming-embedded-python
[edit]
There is a hal-pin that might be useful:
motion.distance−to−go OUT FLOAT
Distance remaining in the current move
[edit]
Last edit: 02 Dec 2020 08:44 by Aciera.
The following user(s) said Thank You: TheRoslyak
- TheRoslyak
- Topic Author
02 Dec 2020 08:49 - 02 Dec 2020 08:49 #190855
by TheRoslyak
Now I do that.
Using halcmd lcec.0.D2.dout-0 1
But may be I can use own new hal componet and any else for solving task?
Last edit: 02 Dec 2020 08:49 by TheRoslyak.
02 Dec 2020 08:54 #190856
sure, can't see why not. Do you need this for all moves or just for some?
- TheRoslyak
- Topic Author
02 Dec 2020 09:05 - 02 Dec 2020 09:06 #190858
by TheRoslyak
Randomly. Now an external script is running that sends linuxcnc rsh command and switch output. To do this, I calculate the time at the script level. But if it is included in the G-code, it will be easier to calculate.
Last edit: 02 Dec 2020 09:06 by TheRoslyak.
02 Dec 2020 09:14 - 02 Dec 2020 09:15 #190860
What about the distance to the end of the path, is that a constant value or does that change?
[edit]
I mean the "t" or "S" value in your picture.
[edit]
Last edit: 02 Dec 2020 09:15 by Aciera.
- TheRoslyak
- Topic Author
02 Dec 2020 09:25 - 02 Dec 2020 10:28 #190861
by TheRoslyak
Constant value. But to find this value need to conduct an experiment to find an acceptable. If calculate in script level I need to change a lot of parameters. If calculate in G-code only one
UPD
motion.distance−to−go It's that me need!!!
Is there a similar variable for time?
UPD
Last edit: 02 Dec 2020 10:28 by TheRoslyak.
02 Dec 2020 10:30 #190863
So, if you write a hal component that constantly switches a pin at the desired distance before reaching the end point you could use M64 P0 with an and2 block to "enable that signal to go out and then M65 P0 to disable the output again. Maybe you could even find a way to automatically disable the output after motion.distance-to-go as reached 0.
Your S value could be defined in the INI or in the GUI.
Just an idea.
Just an idea.
Time to create page: 0.620 seconds
