Strange preview for circular arc (G2/G3)
29 Jan 2026 18:54 #342165 by Finngineering
Strange preview for circular arc (G2/G3) was created by Finngineering
Hello,
I was planning to bore out a disc yesterday and thought I'd handwrite the code. The circular path would be 105 mm in diameter with the center at G54 X0, Y0, and starting at position X-52.5 Y0. Because of my lack of experience, I wrote is as a small program so I could get a preview. But the preview is not what I expected for the:
G2 I52.5 J0 P1
The arc is started from position X-52.5, Y0.
As you can see in the screenshot, the preview shows a strange linear movement and a counter clockwise helix. But when I run the code, the machine makes a 105 mm circle in the XY plane, just as I wanted. The path from this run is visible as well (the red line). I'm guessing I'm doing something wrong, but what?
30 Jan 2026 07:41 #342192 by Aciera
Replied by Aciera on topic Strange preview for circular arc (G2/G3)
Seems to work for me, but maybe you could provide a complete gcode example:
The following user(s) said Thank You: Finngineering
30 Jan 2026 16:27 #342217 by Finngineering
Replied by Finngineering on topic Strange preview for circular arc (G2/G3)
The complete code was visible in the screenshot, but for clarity I include it here:
G17
F500
G2 I52.5 J0 P1
M2
I made a new test with the code you used, and for that the preview is working properly. But if I comment out the G0 move, then the preview is again strange. See the two situations below.
The complete code, with G0 commented out is below:
G17 G21 G40 G43H0 G54 G64P0.005 G80 G90 G94
(G0 X-52.5 Y0)
F1000
G2 I52.5 J0 P1
M2
Maybe this is expected behavior? It certainly wasn't what I expected, but that doesn't mean much. I use LinuxCNC 2.9.2 by the way.
Thank you for having a look. With that the issue is now pinpointed.
30 Jan 2026 17:14 #342218 by MaHa
Replied by MaHa on topic Strange preview for circular arc (G2/G3)
Just in case you want helix milling, you need to set z value for start and end. P is the amount of turns, if z-10 P5, it could look like that, pitch 2
G0 X-52.5 Y0 Z0
F1000
G2 I52.5 J0 Z-10 P5
30 Jan 2026 17:34 - 30 Jan 2026 17:34 #342221 by Finngineering
Yes, helix milling was the end goal. But I was trying to build the program as simple as possible to start with, because I have little experience with anything else than G0/G1. But I got stuck because the preview did not show what I expected for an in-plane (XY) circle.
Thank you for the explanation and test you provided!
Last edit: 30 Jan 2026 17:34 by Finngineering.
30 Jan 2026 17:55 #342222 by MaHa
This toolpath is at centerpoint, so don't forget cuttercompensation. If G41/ / G42 makes trouble, whats not unusual, it can be solved like that. Parameter #5410 is tooldiameter of loaded tool.
G0 X-[52.5 - [#5410 / 2]] Y0 Z0
F1000
G2 I[52.5 - [#5410 / 2]] J0 Z-10 P5
31 Jan 2026 10:57 #342245 by Aciera
Testing on current 2.9.8 with the G0 move commented give me this, which is not quite correct but it's not as wrong as what you got:
01 Feb 2026 12:52 #342278 by Finngineering
Maybe the result depends on the starting position, or some other unknown factor(?)
As such, this is okay for me. I was thinking that maybe a have some strange more or similar enabled. But it appears the preview may require a linear move before arcs.
So maybe a bug in the preview code...
09 Mar 2026 20:22 #344068 by Hannes
Replied by Hannes on topic Strange preview for circular arc (G2/G3)
I just quickly tested it. That's a bug in gmoccapy. In axis, it works.
In axis, you have to reload the gcode after each other move, so the initial position of the circle is updated.
G2's I and J parameters are relative to the last position:
linuxcnc.org/docs/html/gcode/g-code.html#gcode:g2-g3
Now if you don't have a G0 or G1 command before, the preview in gmoccapy looks funny. I think the preview interpreter is not initialized with the actual position in the UI. The real machine interpreter has no issues afterwards.
For the first command, X,Y and Z has to be specified to work. G0 X0 Y0 is not enough, G0 X0 Y0 Z0 does the trick.
I suggest writing a bug report.
09 Mar 2026 20:37 #344069 by Hannes
BTW: Not having a absolute move before a relative move is probably not anything a CAM software would ever do, but it's also not illegal.
However, a "normal" preview tool not knowing where you machine is could not show you anything in that case.
Time to create page: 3.173 seconds
