Newbie - Can I call one ngc file in another?
11 Oct 2009 21:43 #958
by bqgray
Newbie - Can I call one ngc file in another? was created by bqgray
So,
I am developing a series of processes, and it would be very useful to me to be able to call one ngc file from within another ngc file.
This way I could have the machine repeat a figure at anyplace I chose and with any number of iterations.
This programatic ability would be extreemly useful, but I don't seem to see it in the documentation. Something like "#include" in C?
Thanks,
Bill
Thanks,
Bill
11 Oct 2009 23:57 #960
by BigJohnT
Replied by BigJohnT on topic Re:Newbie - Can I call one ngc file in another?
Well it is not an include but a call to another file.
www.linuxcnc.org/docview/html//gcode_main.html#r3_7
12 Oct 2009 21:41 #963
by bqgray
Replied by bqgray on topic Re:Newbie - Can I call one ngc file in another?
Thanks Big John.
I'm very glad to have found that document in general... lots of good stuff in there.
But the portion on file including is not very clear it would seem... or at least it is not very clear to me.
I have been working with two files otest.ngc and square.ngc... just trying to get and file include to work here.
Here are the files...
otest.ngc
g0 x3 z2
o<square.ngc> call square.ngc
g0 x2 z2
m2
square.ngc
o<square> sub
g0 x1 y1 z3
g0 x2 y1
g0 x2 y2
g0 x1 y2
o<square> endsub
m2
I have attempted a good number of permutations of this format, but I have not found anything that successfully runs that code in square.ngc yet.
Any suggestions?
Thanks,
B
otest.ngc
g0 x3 z2
g0 x2 z2
m2
square.ngc
o<square> sub
g0 x1 y1 z3
g0 x2 y1
g0 x2 y2
g0 x1 y2
o<square> endsub
m2
Any suggestions?
Thanks,
B
12 Oct 2009 21:47 #964
by BigJohnT
Bill,
Your real close but to call the file you use this syntax
o<square> call
and that is the letter O not the number zero.
o<square> call
13 Oct 2009 20:47 - 13 Oct 2009 20:49 #973
by bqgray
Hmmm...
I made the correction, but still no love. The execution just skips over the o command. No error, no complaint. Just completely ignored (as usual).
I have the file square.ngc both in the same directory as the otest.ngc file, and also in the directory that is listed in the ini file which step config allways resets to "/home/bgray/emc2/nc_files"
Simply doesn't seem to take?
B
B
Last edit: 13 Oct 2009 20:49 by bqgray.
13 Oct 2009 23:41 - 13 Oct 2009 23:42 #974
by BigJohnT
Bill,
Both files must be in "/home/bgray/emc2/nc_files" to work AFAIK and if you change the directory pointed to by PROGRAM_PREFIX then both files must be in that directory.
Regards
Regards
Last edit: 13 Oct 2009 23:42 by BigJohnT.
Time to create page: 0.108 seconds
