Repeating a job - use Touch Off?
12 Nov 2009 20:47 #1111
by bajaru
Repeating a job - use Touch Off? was created by bajaru
Is the best way to cut multiple parts, to cut the first piece, enter an appropriate offset for the next piece using Touch Off and then cut the next piece and repeat? I've tried this and it seems sometimes it moves the drawing relative to the last cut and sometimes it's an absolute measurement. What I've been doing lately then is to jog to 0, 0, then home X and Y and enter an absolute measurement as the Touch Off value for both X and Y, then cut the next part. This is a a litle cumbersome. Is there a better way?
-Thanks
-BrianB
-Thanks
-BrianB
12 Nov 2009 23:33 #1114
by BigJohnT
Replied by BigJohnT on topic Re:Repeating a job - use Touch Off?
If your talking about cutting several parts from a single piece of material I do that with G92 on my plasma cutter. I set G92 X0 Y0 at the start and after the cut move to the next start position and set G92.1just in case it is the last part... Then I just run the file over again as many times as needed. Each time it cuts the part as if it is starts at X0 Y0.
Time to create page: 0.252 seconds
