User Interfaces
AXIS
Keyboard re-mapping (key binding)
Thank you received: 1
08 Nov 2011 15:27 #14675
by ioiotutu
is it possible remap some commands keys?
I need to swap arrow-left/arrow-right (X moving) with arrow-up/arrow-dn (Y moving). Is there a config file for this?
Thanks,
Michele
Thank you received: 1225
08 Nov 2011 16:49 #14677
by BigJohnT
AFAIK you have edit axis.py to change keyboard mapping. Are you wanting to do this because your machine jogs backwards?
Thank you received: 4800
08 Nov 2011 16:57 - 08 Nov 2011 16:58 #14678
I think so.
linuxcnc.org/docs/html/gui_axis.html#r1_11_4
Though I don't know if that allows you to re-map keys which are already allocated. I also have no idea what the correct syntax is, but you can probably just copy the program lines from inside Axis.
Last edit: 08 Nov 2011 16:58 by
andypugh.
08 Nov 2011 17:14 #14680
by ioiotutu
Thanks,
when i'm in front of the machine i see Y axis: moving right + direction, moving left - direction. X axis moving to me + direction and far to me - direction.
Home position is right - up (far to me).
I hope you understand my bad english!
So when push arrow key i need:
arrow-right -> Y +
arrow-left -> Y -
arrow-up -> X-
arrow-down -> X+
where can i find axis.py?
08 Nov 2011 17:29 #14683
by BigJohnT
Normally when you stand in front of a XYZ machine the X axis is the one that goes left/right, the Y in/out, the Z up,down. Normal machines X+ jogs the tool to the right and Y+ jogs the tool away from you and Z+ jogs the tool up. I say tool because some machines move the spindle in XY and some move the material in XY but relative to the material the tool movement is what you want to move in the correct directions.
Unless you have some strange machine... do you have a photo of it?
08 Nov 2011 17:39 #14685
by ioiotutu
Here is the photo.
If i stay left side all is ok, but usually i stay in front and i confuse me with jog.
08 Nov 2011 19:01 #14690
by BigJohnT
Ok, that makes sense the machine is correct but you don't stand in the conventional position. Have you give any thought to using a joy pad to jog with instead of lugging the keypad to the machine? Otherwise you would have to modify axis.py to change the key bindings. I scanned through the 3400 lines of code and nothing jumped out at me.
The following user(s) said Thank You:
tcninja
08 Nov 2011 21:48 #14701
by BigJohnT
Andy's suggestion to use .axisrc is better than my not so well thought out answer. If it exists, the contents of ~/.axisrc are executed as Python source code just before the AXIS gui is displayed. Putting your changes in .axisrc they won't get overwritten at the next upgrade...
User Interfaces
AXIS
Time to create page: 0.165 seconds
