2.3.0 - allow display of rapids to be disabled
25 Apr 2009 06:07 #149 by Cliffnz
Hi, I see one of the changes in AXIS is the ability to disallow the display of rapid movements. I'm turning this on and off in the GUI but not seeing a difference. The G0's are not displayed. Something I'm doing wrong?.
25 Apr 2009 12:07 #151 by BigJohnT
Do you see any rapids (the blue lines) on the backplot?
Are the rapids after a tool change?
www.linuxcnc.org/docview/html//gcode_mai...l#sub:T:-Select-Tool
25 Apr 2009 12:39 #153 by Cliffnz
The first code tried has no tool changes, just some quick/dirty G0 milling. The backplot is completely empty. With some G1 milling the G0 bits would also not display.
Cliff
25 Apr 2009 16:59 - 25 Apr 2009 17:05 #154 by BigJohnT
That appears to be by design. If you have a G1 first the rapids show up... if you start with a G0 none of the rapids show up until the first G1. If you preceed your G0 line with a G1 by itself the G0 moves show up...
So your not doing anything wrong :)
Last edit: 25 Apr 2009 17:05 by BigJohnT.
Time to create page: 0.078 seconds
