Touchscreen operation with iPad possible?
29 Oct 2012 05:59 #25968
by Regnar
Replied by Regnar on topic Touchscreen operation with iPad possible?
I have been using my Ipod as a pendant for close to 2 years now. Great as I can change buttons around and do just about anything the Keyboard could do. The only Negative I have for it is I cannot use Constant Jogging. Im not a programmer but for some reason the button press on the Ipod is viewed as a quick single button press instead of a press and hold.
Some videos for proof.
The following user(s) said Thank You: careyer
30 Oct 2012 19:51 #26057
by careyer
Replied by careyer on topic Touchscreen operation with iPad possible?
Would you mind to explain me a bit more in detail how you did that?
Is there a software that you have to deploy on the same computer that you run EMC on?
Would you share the settings/profile that you use on your phone?
Best regards
Thomas
Best regards
Thomas
30 Oct 2012 23:26 #26078
by Regnar
No other software is needed you just have to configure the VNC server that is already installed. Its very easy and the steps are here.
hipporemote.com/setup_linux
Making your own custom remote is a little more time consuming but not impossible. I just edited one of the already installed profiles. Maybe 20 minutes of work. What I do like is I can change the buttons around to fit my progression of work. Be aware that is is only a remote keyboard that you are able to create keyboard short cuts. Well worth the 99 cents I payed when they first started up. Knowing what I know now I would pay the 5 bucks. Another thing that is funny is Mach3 works fine for constant jogging.
30 Oct 2012 23:32 #26079
by careyer
Would you mind sharing the profile that you have already created? Best regards
Thomas
Thomas
30 Oct 2012 23:47 #26083
by Regnar
Sure, just later tonight when I can upload it.
31 Oct 2012 00:08 #26085
by careyer
Great!!! Thanks in advance
31 Oct 2012 22:05 #26133
by careyer
Hi Regnar, have you been able to upload your profile somewhere? Thanks in advance!
Thomas
Thomas
01 Nov 2012 12:09 - 01 Nov 2012 12:11 #26172
by Regnar
Im pretty sure this is the right one. It will look a little different then the one in the video as it should have a Zero in the center.
You have to put all 4 files into one folder.
Last edit: 01 Nov 2012 12:11 by Regnar.
01 Nov 2012 12:22 #26174
by Regnar
Sorry it took so long. Had to sign up for Dropbox and such.
www.dropbox.com/sh/ig1zmtzjsue567j/_qWKMVewH4
01 Nov 2012 22:17 #26185
by careyer
Thank you very much... but I have problems to install the profile... can you tell me how to do it?
In HippoRemote I have the possiblity to import a profile by uploading a ZIP file which contains the profile... tried to do that but it does not work?
How is your profile named?
Can you tell me how to upload the profile to my iOS Device?
Thank you very much!
Time to create page: 0.158 seconds
