new in linuxcnc need help
24 Apr 2015 06:16 #58056
by festrito
new in linuxcnc need help was created by festrito
hello I need help with axis 4th rotary axis. I have configured machine with stepconf and all is runing but 4th axis dont vizualize the toolpath. what can be dhe problem? thenks for answer
24 Apr 2015 17:27 #58075
by ArcEye
Replied by ArcEye on topic new in linuxcnc need help
Hi
I don't think there is one, what kind of visualisation were you expecting from a 2D plot of a rotating axis?
If you enter G1 X10 A720 F30 or similar in the MDI window, you will see the tool wrap around the X axis over the distance set.
This is the simulation of a rotating axis, as a rotating line would just look as if it was not moving.
The following user(s) said Thank You: festrito
24 Apr 2015 18:05 #58080
As you rotate the axis you might see the tool cone rotate on the screen.
It is also possible to get this effect: www.linuxcnc.org/index.php/english/forum...s-on-cylinders#40497
The trick is to have a GEOMETRY entry in the [DISPLAY] section of the INI.
www.linuxcnc.org/docs/html/config/ini_co...#sub:DISPLAY-section
You probably want to have AXYZ or XYZA but other options exist..
Replied by andypugh on topic new in linuxcnc need help
25 Apr 2015 16:34 #58110
by festrito
Replied by festrito on topic new in linuxcnc need help
Thanks people ! it works!
Time to create page: 0.150 seconds
