Getting camview-emc to work on wheezy
03 May 2015 19:55 #58350
by jorsborn
Getting camview-emc to work on wheezy was created by jorsborn
I am having troubles getting camview-emc installed on wheezy. I've followed the directions on the wiki as well as psha's site. The repository was added and updated successfully. I am referring to squeeze as it is the latest in the repository (no wheezy). Attempting to add camview-emc I get the following dependency issues:
Any suggestions?
camview-emc : Depends: python-camunits but it is not going to be installed
Depends: camunits-plugins-emc-misc (= 0.0.37) but it is not going to be installed
Any suggestions?
04 May 2015 10:05 #58366
by jmelson
Replied by jmelson on topic Getting camview-emc to work on wheezy
I can't give any specific instructions on that kernel, but I had QUITE a time getting it to work on Ubuntu 10.04 with LinuxCNC.
First, make sure the generic camview works on your system. Then, the major hack to camview is to add a crop function to the string of functions.
By cropping to the center of the camera image, it forces the display to blow up the central part to fill the window. Once you have this working, then
you have to integrate it into Axis.
Jon
Jon
Time to create page: 0.120 seconds
