Touch off is locked up
- allenwg2005
- Topic Author
- Thank you received: 4
18 Jun 2015 05:05 #59925
by allenwg2005
Touch off is locked up was created by allenwg2005
I have changed over to using a EMC post in my CAM software (I was using a "Default mill" post), for some reason LCNC will not let me load offsets, or do a work piece touch off.
Can someone please explain why that would be?
Here are some of the early lines in the file:
N1G17G20 (XY plane, Units)
N2G53G0Z0 (rapid retract quill)
N3G40G49G80 (cancel diameter, length, canned cycles)
N4G55G90G94 (set fixture, absolute, feed/minute)
N5G0X0Y0
N6M05M09
N7(MSG,LOAD T1 .2500 Twist Drill )
N8M00T1M06
N9G00X3.2099Y5.4375S1070M03
N10G04P2.5
N5G0X0Y0
N6M05M09
N8M00T1M06
N10G04P2.5
18 Jun 2015 18:53 #59935
Replied by andypugh on topic Touch off is locked up
What happens when you try to touch-off? How does that differ from what you expect?
- allenwg2005
- Topic Author
18 Jun 2015 20:13 #59938
by allenwg2005
Replied by allenwg2005 on topic Touch off is locked up
When I push a radio button for an axis and go to Touch off, enter a value, pick G54 P1, nothing happens.
It will not even do a work piece touch off.
It will not move the geometry here it needs to be.
It would usually move zero (in my drawing) for that axis to the position the value I entered indicated.
18 Jun 2015 22:04 #59942
You might get this behaviour if the system can't write to the yourconfig.var file.
Try deleting the .var and .var.bak files in the active config folder.
Time to create page: 0.065 seconds
