Reload Program Through Pin
24 Aug 2015 03:01 #61715
Replied by PCW on topic Reload Program Through Pin
Thats why I was suggesting a race condition, a script that changes the mode
may have to wait until the mode change occurs before proceeding with operations that depend on the
requested mode change
24 Aug 2015 03:28 #61717
by BigJohnT
Replied by BigJohnT on topic Reload Program Through Pin
Exactly, if your changing to mdi mode you must wait for halui.mode.is-mdi to be true before marching on in your program.
JT
JT
24 Aug 2015 03:57 #61719
by Delron
Replied by Delron on topic Reload Program Through Pin
Tried all that, I think....
Can you do it in a M-code? Did not seem to work for me.
24 Aug 2015 04:12 #61720
by Delron
Here is one I tried with no success
M101
#!/bin/sh
halcmd setp halui.mode.mdi true
axis-remote -m "o100 call"
halcmd setp halui.mode.manual true
axis-remote —reload &
exit 0
Sure would like to see Linuxcnc create a method to deal with this problem in the next release.
M101
#!/bin/sh
exit 0
24 Aug 2015 04:28 #61721
Still not convinced there is a problem
Nothing you have shown checks that the state has changed to the desired state before proceeding
24 Aug 2015 04:31 - 24 Aug 2015 04:36 #61722
by Delron
I'm not sure where I can check the state from for this to work?
Can the M-code do logic?
Would I place the hali.mode.is-manual in the M-code file and check there?
How do I pause the m-code until it is in manual mode before proceeding with the reload?
Can you give an example?
Last edit: 24 Aug 2015 04:36 by Delron. Reason: More questions
24 Aug 2015 04:40 #61723
by Delron
Ok, I think it's behaving I little more here, however, I cannot get the m-code to put the machine back to manual mode after the reload.??
24 Aug 2015 04:45 #61724
Not the most elegant way but
a bash while loop in your script waiting for
halcmd getp halui.mode.is-mdi | grep true
Having a 0 exit code is a possibility for waiting for mode changes
24 Aug 2015 05:55 #61725
by BigJohnT
I might add this would be a trivial task in Classicladder... turn a pin on and wait for a response is what ladder logic is good at.
JT
JT
24 Aug 2015 06:01 #61727
by Delron
So many hoops to go through just to reload a program after a touch-off.
I think I give up. Was hoping to run my machine mostly from the pendant, but I guess I'll have to keep a keyboard and or mouse nearby.
Time to create page: 0.416 seconds
