Source File For G-Codes
22 Nov 2015 00:05 #65632
by fc60
Source File For G-Codes was created by fc60
Greetings,
I use LinuxCNC 2.5.4 with AXIS.
When the part program is running, AXIS shows a list of active G-codes. However, when running a G73 cycle, the G73 does not show up. I thinking it may be there but truncated due to limited space.
Now to my real question. Where is the active G-code data stored within LinuxCNC? I would like to view the file with an editor.
Cheers,
Dave
Cheers,
Dave
22 Nov 2015 00:41 #65634
by BigJohnT
Replied by BigJohnT on topic Source File For G-Codes
Machine > Show LinuxCNC Status.
JT
JT
23 Nov 2015 16:33 #65702
by fc60
Replied by fc60 on topic Source File For G-Codes
Thanks, found the pick in AXIS.
Sadly, the file is constantly updating and it is difficult to keep the screen steady to read the values.
Again, AXIS is a "front end", yes? It reads and displays the data from a root source?
I would like to know the file that AXIS is extracting and displaying the data from.
Cheers,
Dave
Cheers,
Dave
23 Nov 2015 18:11 #65707
by cncbasher
Replied by cncbasher on topic Source File For G-Codes
it's reading from the Gcode file and any incorporated sub o word macros from your ngc / ngc lib directory
it's quite possible if in a macro , the local values are not displayed . depending on the macro loaded
Time to create page: 0.087 seconds
