A-Axis Jog Values
16 Dec 2015 16:58 #67046
by fc60
A-Axis Jog Values was created by fc60
Greetings,
I was using my 4-axis mill to "reverse engineer" a part.
X,Y, and Z all have JOG values in actual inches, and the axes all move the indicated amount.
A axis does jog + and - ; but, the values are still shown in inches on the JOG menu?
My LinuxCNC is version 2.5.4 and I am using the AXIS interface.
Is this normal? Or, is there a place I can correct the concern?
With kind regards,
David
With kind regards,
David
17 Dec 2015 11:15 #67078
Replied by andypugh on topic A-Axis Jog Values
The increments are set by the iNI
linuxcnc.org/docs/2.7/html/config/ini-co...tml#_display_section
in the INCREMENTS section.
It does not seem to offer the option to jog in degrees. The code in axis does only seem to understand the units mentioned in the docs:
github.com/jepler/linuxcnc-mirror/blob/c...cripts/axis.py#L1277
Does the display actually state the units? My recollection is hazy, but I thought that "0.1" meant 0.1mm or 0.1 degrees.
17 Dec 2015 12:35 #67084
by BigJohnT
Replied by BigJohnT on topic A-Axis Jog Values
You can have the increments without the text "in" and I think it uses the machine units.
JT
JT
17 Dec 2015 18:53 #67098
by fc60
Replied by fc60 on topic A-Axis Jog Values
Greetings,
Many thanks to Big John. I edited out the "in" characters in my INI file and A-axis moves in units appropriate. The JOG drop down box now shows the numerical values with no "in" appended.
Cheers,
David
Cheers,
David
Time to create page: 0.229 seconds
