modification of the name
04 Feb 2016 13:29 #69577
by kalio
modification of the name was created by kalio
Hi all.
This is my first step on the forum so please bear with us.
Please help.
Trying to change the name displayed in the axis - Coolant fluid checkbox. if anyone is able to help me where I can edit the file containing this information ??
Can I change the power button on the spindle to another ??
How to set up automatically when you start to appear top view of the Z-axis,
Thank you for your help
Where can I find language file ??
Please help.
04 Feb 2016 14:39 #69581
Replied by andypugh on topic modification of the name
LinuxCNC has translations into many languages, and Axis is probably the best-translated GUI.
It _should_ pick up your native language from the system locale settings.
If you are interested, the translation files are here:
github.com/LinuxCNC/linuxcnc/tree/master/src/po
Some are more complete than others.
To make a change to a specific string in Axis you would need to edit a file called axis.tcl
This is probably in usr/bin or usr/share, but "locate axis.tcl" should find it.
The following user(s) said Thank You: kalio
04 Apr 2016 09:52 #72691
by kalio
Replied by kalio on topic modification of the name
Hello
Thank you very much. Super accurate answer
Time to create page: 0.078 seconds
