how to modify the color of background of AXIS
- chuchengbing
04 Aug 2016 02:46 #78342
by chuchengbing
how to modify the color of background of AXIS was created by chuchengbing
Hello everyone.
Now I want to make some changes on AXIS gui. I have changed something by modify the axis.tcl and axis.py files. But I can not change the background color of the axis gui, which is always grey, including when start the linuxcnc, there is a configuration selector which let you to choose which configuration you have done will be loaded. I find that it is not a easy work to change this background color too. I am new in python. So, it is better someone will give me clues. thanks very much...
04 Aug 2016 14:49 - 04 Aug 2016 14:53 #78360
by loboy
Replied by loboy on topic how to modify the color of background of AXIS
Hello chuchengbing,
To change the background color of elements in the Axis GUI, I would take a look at "frame" widgets in the axis.tcl file. The frame widget is used to group things together in a box. You will have to add a color attribute to these.
The first one you can specifically look at is on LINE 469:
Replace it with the color of your choosing... You can also use hexidecimal color values.
There are many other frame widgets which you may have to add a background color attribute. Hopefully this gets you pointed in the right direction.
I am not sure of what you mean by the "configuration selector" ?
frame .toolbar \
-borderwidth 1 \
-relief raised \
-background "green"
Last edit: 04 Aug 2016 14:53 by loboy.
The following user(s) said Thank You: chuchengbing
- chuchengbing
05 Aug 2016 01:09 #78375
by chuchengbing
Replied by chuchengbing on topic how to modify the color of background of AXIS
Thanks loboy.
yes,you are right, I have done something like you told and it really changed some color of frame. but what i want to change is the color of the whole axis gui. I am not sure you will understand me. anyway, thanks very much!!
05 Aug 2016 15:55 #78391
by loboy
As I stated before, you will have to add color attributes to multiple widget elements. The entire background is not controlled by a single widget element, it is composed of multiple frame boxes (sometimes nested) all of which need color attributes. The grey that you are seeing is the default color Tcl uses when no color attribute is assigned.
For example there is another frame widget at LINE 810, another at LINE 863, 899... etc.
Time to create page: 0.070 seconds
