User Interfaces
AXIS
Rounded Corners / MAX_FEED_OVERRIDE
Thank you received: 73
22 Dec 2016 13:46 #84553
by OT-CNC
I will try to replicate it again when I get back to the shop. I'm glad the rounding was large enough to be noticeable during dry run.
There was some other issue I was having with a small corner radius that didn't always cut. 5 out of 30 parts looked like the radius reversed or bridged with a linear move(s) during the contour. Is it possible for the trajectory planner to alter the path from cycle start to cycle start?(machine was not shut down in between) I would expect it to always give the same results, no? Also, parts measured up within .0005" or better. I don't think it's a mechanical issue.
User Interfaces
AXIS
Time to create page: 0.058 seconds
