[solved]axis error 230 ??
14 Jan 2017 14:30 - 19 Jan 2017 15:56 #85752
by bkt
[solved]axis error 230 ?? was created by bkt
these error appear when in halui.mdi.mode state (halui.is-mdi active) an MDI command launched halui.mdi.0-command ends ..... (These command is a subroutine NGC declared in the .ini file halui section as MDI = O <mysoub> CALL ....)
the error is similar to these (not have the machine in front of me):
or similar ... the error code is 230 and really not set the teleop during mdi execution .... is normal or must find the problem with halscope??
Giorgio
EMC_TELEOP_SET_ENABLED error 230 try to enable telop from MDI
Giorgio
Last edit: 19 Jan 2017 15:56 by bkt.
19 Jan 2017 15:56 #86160
by bkt
Replied by bkt on topic [solved]axis error 230 ??
wrong sequence of command.....
Miki
Miki
- Thank you received: 5874
19 Jan 2017 17:35 #86174
You changed your name ????
Replied by tommylight on topic [solved]axis error 230 ??
Miki <======?????????
The following user(s) said Thank You: bkt
26 Jan 2017 17:59 #86724
by bkt
Miki or Big Miki is my nikname ....I gave him my business friends .... a bit 'for the look a bit' for the way we do at times ... so in some other forum my sign is miki ...
Hello tommylight... have a good night ...
mine is good I have finally ubuntu kernel 4.8.15 working with quite good servo thread latency ....
Regards
Giorgio/Miki
Regards
Giorgio/Miki
Time to create page: 0.201 seconds
