Axis german translation
- Holzwurm56
18 Jan 2017 09:39 #86037
by Holzwurm56
Axis german translation was created by Holzwurm56
Hello,
is there a special file where the german words for the axisdisplay are stored?
Hans
Hans
18 Jan 2017 19:15 #86081
by BigJohnT
Replied by BigJohnT on topic Axis german translation
All translations are in .po files, in a RIP (Run In Place) they are located in /src/po.
JT
JT
- Holzwurm56
18 Jan 2017 20:14 #86087
by Holzwurm56
Replied by Holzwurm56 on topic Axis german translation
Hello JT,
can you tell me the complete path?
Hans
Hans
18 Jan 2017 20:19 - 18 Jan 2017 20:20 #86088
Replied by PCW on topic Axis german translation
You should be able to find the linuxcnc po file with locate
for example:
locate po.de
(you will get some non-linuxcnc hits as well)
for example:
locate po.de
Last edit: 18 Jan 2017 20:20 by PCW.
18 Jan 2017 21:55 #86098
by BigJohnT
He might have better luck with
locate de.po
JT
locate de.po
JT
19 Jan 2017 09:23 #86134
Replied by rodw on topic Axis german translation
I'm assuming the language .po files are some kind of a standard. I did some translation of an accounting program into Australian to meet our Tax compliance rules. I used this software which they said to use and it made the job so easy!
poedit.net/
Good luck!
poedit.net/
Good luck!
Time to create page: 0.144 seconds
