AXIS memory leak == 2.8.0-pre1
12 Mar 2017 16:47 - 12 Mar 2017 18:25 #89472
by jCandlish
AXIS memory leak == 2.8.0-pre1 was created by jCandlish
I woke this morning to a hung machine due to thrashing caused by a memory leak.
I see now with 'top' that the axis process is consuming memory.
This is with 2.8.0-pre1-2910-g2aaae01.
I tried going back to 2.7 but that is dumping core with:
How to proceed?
=======edit========
The leak consumes 10% of memory per hour on a 4G machine.
rtapi_app: caught signal 11 - dumping core
How to proceed?
=======edit========
Last edit: 12 Mar 2017 18:25 by jCandlish.
12 Mar 2017 18:24 - 12 Mar 2017 18:25 #89477
Replied by PCW on topic AXIS memory leak == 2.8.0-pre1
I would say that axis leaking major amounts of memory is unusual
( i have 2.8 test setups running axis for months on end 24/7 with no issues )
Do you have a very large gcode file loaded?
What is your system like otherwise (hardware/memory/OS etc) ?
Last edit: 12 Mar 2017 18:25 by PCW.
12 Mar 2017 18:32 - 12 Mar 2017 18:36 #89478
by jCandlish
Replied by jCandlish on topic AXIS memory leak == 2.8.0-pre1
Our posts crossed.
AXIS leaks at idle, with only the banner g-code loaded.
Debian Stretch.
Linux 125cnc 4.9.0-2-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.13-1 (2017-02-27) x86_64 GNU/Linux
7i80 => 7i47 => (7i84 + 7i73)
Debian Stretch.
latheoperator@125cnc:~$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 78
model name : Intel(R) Celeron(R) CPU 3855U @ 1.60GHz
stepping : 3
microcode : 0x9e
cpu MHz : 628.125
cache size : 2048 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave rdrand lahf_lm abm 3dnowprefetch epb intel_pt tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust erms invpcid rdseed smap clflushopt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp
bugs :
bogomips : 3216.00
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 78
stepping : 3
microcode : 0x9e
cpu MHz : 720.117
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 3217.15
clflush size : 64
power management:
latheoperator@125cnc:~/linuxcnc/configs/work/CNC_003$ free
total used free shared buff/cache available
Mem: 3928812 251580 3260956 52740 416276 3563052
Swap: 6369276 0 6369276
latheoperator@125cnc:~/linuxcnc/configs/work/CNC_003$ mesaflash --verbose --device 7i80 --addr 10.100.10.100 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I80
FPGA Size: 16 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 24
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3500
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5A00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Configuration pin-out:
IO Connections for P1
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 1 Step/Table1 (Out)
3 1 IOPort StepGen 1 Dir/Table2 (Out)
5 2 IOPort StepGen 2 Step/Table1 (Out)
7 3 IOPort StepGen 2 Dir/Table2 (Out)
9 4 IOPort SSerial 0 RXData1 (In)
11 5 IOPort MuxedQCount 1 MuxQ-A (In)
13 6 IOPort SSerial 0 RXData2 (In)
15 7 IOPort MuxedQCount 1 MuxQ-B (In)
17 8 IOPort None
19 9 IOPort MuxedQCount 1 MuxQ-IDX (In)
21 10 IOPort MuxedQCount 0 MuxQ-A (In)
23 11 IOPort MuxedQCount 2 MuxQ-A (In)
25 12 IOPort MuxedQCount 0 MuxQ-B (In)
27 13 IOPort MuxedQCount 2 MuxQ-B (In)
29 14 IOPort MuxedQCount 0 MuxQ-IDX (In)
31 15 IOPort MuxedQCount 2 MuxQ-IDX (In)
33 16 IOPort StepGen 3 Step/Table1 (Out)
35 17 IOPort StepGen 3 Dir/Table2 (Out)
37 18 IOPort StepGen 4 Step/Table1 (Out)
39 19 IOPort StepGen 4 Dir/Table2 (Out)
41 20 IOPort SSerial 0 TXData1 (Out)
43 21 IOPort SSerial 0 TXData2 (Out)
45 22 IOPort StepGen 0 Step/Table1 (Out)
47 23 IOPort StepGen 0 Dir/Table2 (Out)
IO Connections for P2
1 24 IOPort None
3 25 IOPort None
5 26 IOPort None
7 27 IOPort None
9 28 IOPort None
11 29 IOPort None
13 30 IOPort None
15 31 IOPort None
17 32 IOPort None
19 33 IOPort None
21 34 IOPort None
23 35 IOPort None
25 36 IOPort None
27 37 IOPort None
29 38 IOPort None
31 39 IOPort None
33 40 IOPort None
35 41 IOPort None
37 42 IOPort None
39 43 IOPort None
41 44 IOPort None
43 45 IOPort None
45 46 IOPort None
47 47 IOPort None
IO Connections for P3
1 48 IOPort None
3 49 IOPort None
5 50 IOPort None
7 51 IOPort None
9 52 IOPort None
11 53 IOPort None
13 54 IOPort None
15 55 IOPort None
17 56 IOPort None
19 57 IOPort None
21 58 IOPort None
23 59 IOPort None
25 60 IOPort None
27 61 IOPort None
29 62 IOPort None
31 63 IOPort None
33 64 IOPort None
35 65 IOPort None
37 66 IOPort None
39 67 IOPort None
41 68 IOPort None
43 69 IOPort None
45 70 IOPort None
47 71 IOPort None
latheoperator@125cnc:~$ mesaflash --verbose --device 7i80 --addr 10.100.10.100 --sserial
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 2
SSLBP Baud Rate: 2500000
interface type: 12
interface width: 8
SSLBP Channel Start: 112
SSLBP Channel Stride: 50
SSLBP Processor Type: d8
SSLBP Clock: 100 MHz
sserial device at channel 0: 7I84
SwRevision = 15
HwRevision = 1
NVBaudRate = 2.5Mb
NVUnitNumber = 0x180000F3
NVWatchDogTimeout = 50ms
EncMode0 = ffff [16 bits UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0998]
EncMode1 = ffff [16 bits UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 099A]
NVEncMode0 = 0 [16 bits NV UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0066]
NVEncMode1 = 0 [16 bits NV UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0068]
SOFTWARE MODE Input_Output [index 00]
SOFTWARE MODE IO_Analog_FieldVoltage [index 01]
SOFTWARE MODE IO_Encoder_Analog [index 02]
sserial device at channel 1: 7I73
Contrast = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 09C6]
EncMode0 = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0998]
EncMode1 = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 099A]
EncMode2 = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 099C]
EncMode3 = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 099E]
SwRevision = 14
HwRevision = 1
KeyMode = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 09DE]
NVContrast = 2710 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0044]
NVEncMode0 = 0 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 003A]
NVEncMode1 = 0 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 003C]
NVEncMode2 = 0 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 003E]
NVEncMode3 = 0 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0040]
NVDispMode = 414 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0006]
NVKeyTimer = 1e [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0046]
NVAnalogFilter = 8000 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0042]
NVBaudRate = 2.5Mb
NVUnitNumber = 0x130000E2
SOFTWARE MODE InputOutputEncoder [index 00]
SOFTWARE MODE InputOutputEncoderAnalog [index 01]
SOFTWARE MODE InputOutputEncoderAnalog [index 02]
SOFTWARE MODE InputOutputEncoderDisplay [index 00]
SOFTWARE MODE InputOutputEncoderAnalogDisplay [index 01]
SOFTWARE MODE InputOutputEncoderAnalogWideDisplay [index 02]
SOFTWARE MODE InputOutputEncoderKeycode4by8 [index 00]
SOFTWARE MODE InputOutputEncoderAnalogKeycode4by8 [index 01]
SOFTWARE MODE InputOutputEncoderAnalogKeycode4by8 [index 02]
SOFTWARE MODE InputOutputEncoderDisplayKeycode4by8 [index 00]
SOFTWARE MODE InputOutputEncoderAnalogDisplayKeyCode4by8 [index 01]
SOFTWARE MODE InputOutputEncoderAnalogWideDisplayKeyCode4by8 [index 02]
SOFTWARE MODE InputOutputEncoderKeycode8by8 [index 00]
SOFTWARE MODE InputOutputEncoderAnalogKeyCode8by8 [index 01]
SOFTWARE MODE InputOutputEncoderAnalogKeyCode8by8 [index 02]
SOFTWARE MODE InputOutputEncoderDisplayKeycode8by8 [index 00]
SOFTWARE MODE InputOutputEncoderAnalogDisplayKeyCode8by8 [index 01]
SOFTWARE MODE InputOutputEncoderAnalogWideDisplayKeyCode8by8 [index 02]
Last edit: 12 Mar 2017 18:36 by jCandlish. Reason: added attachments
12 Mar 2017 19:00 - 12 Mar 2017 19:03 #89480
Weird, possible stretch or dependencies related?
( I notice Stretch is not officially supported so there could definitely be issues there )
I have 4 systems running axis 24/7, never noticed a memory leak
but I'm not running stretch or a 4.9 kernel
systems:
CoreDuo E8500 Ubuntu 16.04 4.1.xx kernel
CoreDuo E8500 Mint18.1 4.1.xx kernel
I5-3770 Mint18.1 4.4.xx kernel
N3355 Wheezy 4.1.xx kernel
also have run but not running currently
n3150 Mint 17 4.4.xx kernel
G3258_H97 Wheezy 4.1.xx kernel
I've run both 2.7 and 2.8 pre on all, never a axis memory leak issue
systems:
Last edit: 12 Mar 2017 19:03 by PCW.
- Thank you received: 5904
12 Mar 2017 19:11 #89481
Replied by tommylight on topic AXIS memory leak == 2.8.0-pre1
Debian wheezy, linux mint 17.3 64bit, linux mint 18.1 32bit.
No such problems, weeks at a time.
Those are all on production machines running all day every day.
12 Mar 2017 19:18 #89484
by jCandlish
All my other systems are Strech so going back to Jessie is a bit clunky.
I'll create a Jessie partition on this test machine tomorrow and see if the leak persists.
I do note that there have been leaks before. What has been the effective approach for squashing them?
12 Mar 2017 19:20 #89485
by grump
Replied by grump on topic AXIS memory leak == 2.8.0-pre1
I am running on the same Stretch Linux_image 4.9.0-2-rt-amd64 SMP PREEMPT RT Debian 4.9.13-1.
LXDE, Google Chrome constantly connected to my drive and using cloud cad.
Running a four axis machine via parport on an old laptop with no issues to report as yet been on since 02-03-17.
I can't fault the software or the laptop only my skills in using them with the cnc.
Good luck, hope you get it sorted soon.
12 Mar 2017 19:20 #89486
by jCandlish
When you follow the beaten path the terrain is familiar.
12 Mar 2017 19:32 #89487
Yes it is, although i have plenty more but not used daily. I still have 2 machimes that use ubuntu 10.04 with Linuxcnc in use for over 4 years, never fail, used daily but not all day and they are turned off every evening.
From experience, loooooong time ago, that type of "leak" can be caused by a bad memory controller.
Linux has processor load and system load, check the latter. If it goes often to 200, that is a sign of something wrong with sot or hardware.
Regards,
Tom
Regards,
Tom
13 Mar 2017 10:46 #89509
by jCandlish
Installing on Jessie appears to have resolved the memory leak. It must have been caused subtle dependency of package versions.
Running master-rt on Jessie requires a backported PREEMPT RT kernel, and backported glx and intel firmwares if your motherboard has an integrated intel graphics chipset.
backports snipped for /etc/apt/sources.list
needful backported packages
# backports
deb http://ftp.ch.debian.org/debian/ jessie-backports main contrib non-free
deb-src http://ftp.ch.debian.org/debian/ jessie-backports main contrib non-free
latheoperator@125cnc:~$ dpkg-query -l | grep ~bpo8 | awk '{print $2}'
firmware-misc-nonfree
firmware-realtek
intel-gpu-tools
iucode-tool
libdrm-amdgpu1:amd64
libdrm-dev:amd64
libdrm-intel1:amd64
libdrm-nouveau2:amd64
libdrm-radeon1:amd64
libdrm2:amd64
libgl1-mesa-dri:amd64
libglib2.0-0:amd64
libglib2.0-bin
libglib2.0-dev
libllvm3.8:amd64
libva1:amd64
linux-base
linux-compiler-gcc-4.9-x86
linux-headers-4.9.0-0.bpo.2-common-rt
linux-headers-4.9.0-0.bpo.2-rt-amd64
linux-headers-rt-amd64
linux-image-4.9.0-0.bpo.2-rt-amd64
linux-image-rt-amd64
linux-kbuild-4.9
xserver-xorg-video-intel
latheoperator@125cnc:~$ uname -a
Linux 125cnc 4.9.0-0.bpo.2-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.13-1~bpo8+1 (2017-02-27) x86_64 GNU/Linux
latheoperator@125cnc:~/linuxcnc$ linuxcnc
LINUXCNC - 2.8.0-pre1-2912-g2636009
Machine configuration directory is '/home/latheoperator/linuxcnc/configs/work/CNC_003'
Machine configuration file is 'CNC_003.ini'
Starting LinuxCNC...
(time=1489400763.016967,pid=7358): Registering server on TCP port 5005.
(time=1489400763.017573,pid=7358): running server for TCP port 5005 (connection_socket = 3).
iocontrol: machine: 'CNC_003' version 'unknown'
Found file(REL): ./CNC_003.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
The following user(s) said Thank You: Nico2017
Time to create page: 0.132 seconds
