Keyboard shortcuts
- massimodamassa
- Topic Author
- Thank you received: 9
19 Jun 2017 07:34 #94690
by massimodamassa
Keyboard shortcuts was created by massimodamassa
I would like to remove the keyboard shortcuts in axes, especially F1 and F2, which are very dangerous.
I tried in the axis.tcl file to comment on accelerators but without getting a result.
Thank you all
Thank you all
19 Jun 2017 12:15 #94695
by billykid
Replied by billykid on topic Keyboard shortcuts
I am trying, when i can i tell you
19 Jun 2017 12:34 #94696
by jtc
Replied by jtc on topic Keyboard shortcuts
The following user(s) said Thank You: massimodamassa
- massimodamassa
- Topic Author
19 Jun 2017 16:11 #94704
by massimodamassa
Replied by massimodamassa on topic Keyboard shortcuts
Thanks for the suggestion, actually adding these lines root_window.unbind ("<F1>") and root_window.unbind ("<F2>")
In the .axisrc file I disable only the emergency and not the power, I would need to delete all the keyboard shortcuts, they are useless and dangerous.
19 Jun 2017 16:55 #94705
by billykid
He means no keyboard shortcut because it can be dangerous to accidentally touch a button and move the cnc.
Is there a way to disable them all?
Mauro
Mauro
- massimodamassa
- Topic Author
20 Jun 2017 05:34 #94716
by massimodamassa
It's better to call it a shortcut to make damage, but in my opinion I have to act on the file accel.tcl and axis.tcl but here should be answered by emc developers or some programmers.
I do not understand how they may have overlooked such a great detail on so well-made software.
Greetings
Greetings
20 Jun 2017 22:54 #94747
The Axis GUI is a keyboard GUI, it is intended to be operated with a keyboard.
There are other GUIs that have different focuses.
Replied by andypugh on topic Keyboard shortcuts
- massimodamassa
- Topic Author
21 Jun 2017 05:33 #94752
by massimodamassa
Even with other GUIs if I press F1 and F2 I get the same result.
21 Jun 2017 08:09 #94755
by tecno
Replied by tecno on topic Keyboard shortcuts
Here a simple solution to your problem = make a mechanical cover over F1/F2 keys
Then you can not accidentally use F1/F2.
- massimodamassa
- Topic Author
21 Jun 2017 08:35 #94756
by massimodamassa
I had already thought about it, just wanting to eliminate all the quick keys, the machine's command from the panel.
The keyboard would only be used to write to MDI or edit the program.
