Get Gcode properties in txt file
31 Aug 2017 23:55 #98316
by Nico2017
Get Gcode properties in txt file was created by Nico2017
is there a way to extract the information of the File Gcode properties and save it to a txt file? Would like to save those basic information to see how far I am from the run time (even if does not take the acceleration into account).
Thank you
Nicolas
Thank you
Nicolas
22 Apr 2021 02:37 #206759
by Nico2017
Replied by Nico2017 on topic Get Gcode properties in txt file
still looking on this topic I would like to get the overall distance travelled from a Gcode file. Is there any function already pre made somewhere which can have a look at this?
Thank you,
Nicolas
Thank you,
Nicolas
22 Apr 2021 07:39 #206772
Replied by cmorley on topic Get Gcode properties in txt file
Yes but it is buried in AXIS python code.
When the file is loaded the properties are calculated.
You could probably use .axisrc file to make a function to read and save it.
I'm not at a computer to point u closer to the code.
- OttoDidact
06 Sep 2021 07:48 #219740
by OttoDidact
Replied by OttoDidact on topic Get Gcode properties in txt file
I've been thinking for a while about how usefull this information would be for maintenance purposes. If you had mileage data for each axis, you'd know when to grease the bearings. It could also provide some idea about how much life I'm getting out of my bits.
The other utility would be knowing how long a file will take to cut approximately. Fortunately at some point I discovered SheetCam has that functionality. It would be a great feature for LinuxCNC.
08 Sep 2021 12:32 #219935
by BigJohnT
Replied by BigJohnT on topic Get Gcode properties in txt file
If you define a user command file in the ini and add commands.gcode_properties() it pops up the properties window but gcode_properties() does not return any information.
/src/usr_intf/axis/scripts/axis.py line 1978 is where gcode properties is, you could create a similar function to print that information to a file.
JT
JT
The following user(s) said Thank You: Nico2017
Time to create page: 0.138 seconds
