Tool compensation question
13 Dec 2023 16:55 #288055
by ckuecker
Tool compensation question was created by ckuecker
Running axis on a gantry mill - get this message when I try to run my program. "Error - Length of cutter compensation entry move is not greater than the tool radius". I can't find a reference to this message in the forum.
Tool is 1/8" end mill.
The program ran without the g42 line.
#<count> = 1 (Number of parts)
#<width> = 0.75 (Thickness of part)
#<length> = [[#<width> * #<count>] + 1]
#<cut_depth> = -0.05 (Depth of each pass)
#<feed> = 10 (Feed rate)
t1
g40 (comp off)
s18000 m03 (Spindle 18,000 RPM, turn on clockwise)
g20 (inch mode)
g90 (absolute mode)
g54 (fixture zero)
g42 (tool comp)
g04 p2 (pause for spindle runup)
(Loop to cut slots)
(Params: #1 = incremental cut depth)
( #2 = ending depth >= #1)
( #3 = length of cut)
( #4 = feed rate)
( #5 = current cut depth)
o100 sub
#5 = #1 (Initial cut)
o101 do
g0 z[#5]
g1 y[#3] f [#4] (make a cut)
g0 y0 (return to start)
o102 if [#5 EQ #2] (end of loop)
o100 return
o102 endif
#5 = [#5 + #1] (go deeper)
o103 if [#5 LT #2] (went too deep!)
#5 = #2
o103 endif
o101 while [#5 GE #2]
o100 endsub
(First six slots)
g1 x0 y0 z0 f100
g1 x0.45 f100 (Start of first cut)
o100 call [#<cut_depth>] [-0.1] [#<length>] [#<feed>]
g1 x0.78 f100
o100 call [#<cut_depth>] [-0.34] [#<length>] [#<feed>]
g1 x1.10 f100
o100 call [#<cut_depth>] [-0.5] [#<length>] [#<feed>]
g0 x0 y0 z0
m2
t1
g40 (comp off)
g20 (inch mode)
g90 (absolute mode)
g54 (fixture zero)
g42 (tool comp)
(Loop to cut slots)
( #4 = feed rate)
o100 sub
o101 do
g0 z[#5]
o100 return
o102 endif
#5 = #2
o103 endif
o100 endsub
(First six slots)
g1 x0 y0 z0 f100
g1 x0.78 f100
g1 x1.10 f100
g0 x0 y0 z0
m2
13 Dec 2023 17:43 #288059
Replied by Aciera on topic Tool compensation question
This may give you some insight (towards the bottom):
linuxcnc.org/docs/html/gcode/tool-compensation.html
14 Dec 2023 16:12 #288134
by ckuecker
Replied by ckuecker on topic Tool compensation question
Added
g10 l1 p1 r0.0625
g42 (tool comp)
to the program. When I run it, the spindle starts and the machine goes to the start position, then just sits there with no indication what G code line is running or next.
g40 (comp off)
g20 (inch mode)
g90 (absolute mode)
g54 (fixture zero)
g0 x0 y0.3 z0
t1
g10 l1 p1 r0.0625
g42 (tool comp)
(Loop to cut slots)
( #4 = feed rate)
o100 sub
o101 do
g0 z[#5]
o100 return
o102 endif
#5 = #2
o103 endif
o100 endsub
(First six slots)
g1 x0.78 f100
g1 x1.10 f100
g0 x0 y0 z0
m2
g10 l1 p1 r0.0625
g42 (tool comp)
g40 (comp off)
g20 (inch mode)
g90 (absolute mode)
g54 (fixture zero)
g0 x0 y0.3 z0
t1
g10 l1 p1 r0.0625
g42 (tool comp)
(Loop to cut slots)
( #4 = feed rate)
o100 sub
o101 do
g0 z[#5]
o100 return
o102 endif
#5 = #2
o103 endif
o100 endsub
(First six slots)
g1 x0.78 f100
g1 x1.10 f100
g0 x0 y0 z0
m2
14 Dec 2023 16:44 #288137
The following user(s) said Thank You: ckuecker
14 Dec 2023 17:02 #288140
by ckuecker
The code ran fine before I put in the compensation code. I don't have an encoder on my spindle - do I have to set that parameter to 1 explicitly?
14 Dec 2023 19:48 #288151
by ckuecker
More info - the code runs up to the same point and hangs with the spindle running. If I stop the program and try to reload the file, it will not run at all. I have to end LinuxCNC and restart.
15 Dec 2023 06:40 #288186
Without spindle feedback you would usually force the pin in your hal file with something like this:
setp spindle.0.at-speed 1
Seems odd though that it worked before.
Does it run in a simulation config ? (You may have to reduce the spindle speed to say 1600rpm as the simulation spindle may be set to a max speed lower than your 16000)
15 Dec 2023 18:06 #288248
by ckuecker
CNC1.hal has this already:
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
I have not tried a simulation - I've never had this issue before, and I've run a few programs successfully, even if they were not written optimally. I'm a C and assembly programmer - slowly learning G-code.
18 Dec 2023 13:36 #288484
by ckuecker
Ran the simulation. It runs, but it appears the return path after each cut will blast through material I do not want cut.
The program before compensation had the cutter return at high speed through the slot just machined. The slots are 1/8" wide, and the cutter is 1/8" diameter.
All I want is for the left side of the cutter to follow the left edge of the slot. I still have no idea why the program hangs after starting the spindle.
Maybe I don't actually want to turn on compensation? An offset of 0.0625" might do the job, but I really need to understand how to use compensation for future jobs.
18 Dec 2023 17:40 #288498
You have compensation active on the return path as well.
