axis don't work with long file
- RobotMatic
- Topic Author
- Thank you received: 21
29 Jul 2009 20:37 #649
by RobotMatic
axis don't work with long file was created by RobotMatic
I'm working with EMC2 2.3.1 on axis screen user. When the file with G code is very long, Axis crash !!!!.
Axis load the full file and drawing it, and the user sleep a lot of time in this operation.
this situation repeat when set posicion axi and axis redraw the path.
axis load long file in bock for execute ?
Thank!. Eduardo Gonzalez from Argentina
29 Jul 2009 23:35 #651
by BigJohnT
Replied by BigJohnT on topic Re:axis don't work with long file
Try turning off the preview.
- RobotMatic
- Topic Author
30 Jul 2009 13:06 #655
by RobotMatic
Replied by RobotMatic on topic Re:axis don't work with long file
thank, but turn off the preview is the same, The G code file is read when the file is load. This is the axis error for long file !!!. Long file dont'n need preview, because this file is make with cam Sofware, and must read it on block for execute.
regards Nestor Eduardo Gonzalez (Argentina)
30 Jul 2009 14:26 #656
by BigJohnT
You have a couple of options:
Add more RAM as Axis loads the text of the file into memory to display it at the bottom.
Use an interface that does not load the text such as Mini.
Reduce the size of your part program.
- RobotMatic
- Topic Author
30 Jul 2009 17:44 #657
by RobotMatic
thank !!! .
Your solution is very simply, I'm need dom't have problem with the long file, My solution is load and execute the long file by block in ram memory, it's posible with axis on emc 2.3.1 or emc 2.3.2 ?????
who can create this funcion for this problem???
in others cnc (Fanuc, Fagor, Hass) this funcion is DNC. And maxnc (pc sofware for dos) have it!!!!.
Regards!!! Nestor Eduardo Gonzalez (Argentina).
30 Jul 2009 18:41 #660
by BigJohnT
EMC does not have DNC... so you will have to pick one of the above options or code one yourself.
- RobotMatic
- Topic Author
30 Jul 2009 18:44 #661
by RobotMatic
ok !! thank john a lot.!!!!
Time to create page: 0.133 seconds
