Can I scale down in size?
11 Oct 2009 12:34 #954
by cwebs
Can I scale down in size? was created by cwebs
I have a DXF that I converted to gcode with "DXF2GCODE". How ever it is to large to fit within the limits of my router. Is there a way to scale it down ? Other then learning Cad, CAM and EMC, I think emc is great. Thanks Carl
11 Oct 2009 13:54 #956
by BigJohnT
Replied by BigJohnT on topic Re:Can I scale down in size?
Hi Carl,
There is no "scale setting" in EMC that I know of. The easiest way is to open up the DXF and scale the drawing the send it back through your g code converter. Depending on how you are set up you might need to move the drawing after you scale it so your favorite point is where it is should to be. For me I put the left rear corner of the part or material at X0 Y0 and the top at Z0.
Regards
Regards
11 Oct 2009 18:03 #957
by cwebs
Replied by cwebs on topic Re:Can I scale down in size?
I found the answer! After playing around in "DXF2GCODE" I can rotate and scale it. This little programs does more then I first knew. Thanks Carl
Time to create page: 0.063 seconds
