Passing a value in a spinbox to GCode command
pull master, and take the MDI Command action in a gladevcp panel. There's an example in the gladevcp docs to do this.
While that builds, have a look at the docs here: emc.mah.priv.at/docs-gladevcp/html/gui/g...an_o_word_subroutine
-Michael
ps: (this is a work-in-progress link and might change)
You might try a recent buildbot build from here: buildbot.linuxcnc.org/
-Michael
There were problems with subs on some of the earlier versions.
Rick G
- photomankc
- Thank you received: 4
I'm assuming that there must be some sort of bug here because it only goes bad when called as a subroutine. In every other situation it works a peach.
2.4 series does not allow calling M66 and lot of other codes from O-subs in MDI mode
- photomankc
Well, it was a neat idea. I changed the interface last night and setup buttons for the 4 corners I can touch to with the common +/-0.100" offset hard coded. The back-left is then shared with my Logitech pendant buttons. That's the most common touch off scenario for me. I added buttons to zero X,Y, and Z in place as well for zeroing on a bore or hole. I have a couple spin boxes to set that offset later when I go to 2.5
I'd be a little nervous to use the development release although I expect it's probably fairly stable now. If you guys think that it's pretty safe then I guess I could go on and setup apt-get to pull that one. I just got my pyVCP implementation working so I'm not exactly aching to change that all up now.
2.5 is close to release, 2.6 is the new bleeding-edge version. I have been using 2.5 for several months, and it is just as stable as 2.4, but with extra features.
- photomankc
Not that I am aware of. I am running 2.5 on what started off as a 2.3 live-CD install. However, I did compile it there, as I tinker with a bit of emc2 development.Do you need to upgrade anything else in Ubuntu to get there?
Rick G
