led pyvpc
22 Mar 2012 21:55 #18721
by BigJohnT
Replied by BigJohnT on topic Re:led pyvpc
You can turn on and off pyvcp leds from the M1xx files, look at the M1xx examples in the manual.
24 Mar 2012 10:54 #18753
by lorisdag
Replied by lorisdag on topic Re:led pyvpc
Hello John, I read the manual but I can not, in my cnc
I turn on the vacuum pump with the code in the m120 and would like to gcode
axis in turn led to a monitor if it is turned on or not
thanks lorisdag
thanks lorisdag
24 Mar 2012 11:59 #18755
by BigJohnT
Can you post the code your having problems with and try and explain the problem in a bit more detail. I can't understand what your question is...
24 Mar 2012 15:02 - 24 Mar 2012 17:39 #18757
by ArcEye
Replied by ArcEye on topic Re:led pyvpc
Hi
I think I understand what you are asking, here is an example
Create a LED called say led1 in your pyvcp script ( normally custompanel.xml) with something like
When your vacuum pump is active, from your M120 script call
halcmd setp pyvcp.led1 true (it will show red)
When the vacuum pump turns off again call
halcmd setp pyvcp.led1 false (it will show green)
led1 does not have to be connected to anything at all for this to work, but you may have to set its default state in your custom_postgui.hal file on startup.
<vbox>
<hbox>
<label><text>" red led "</text><font>("Helvetica",8)</font></label>
<led>
<halpin>"led1"</halpin>
<size>15</size>
<on_color>"red"</on_color>
<off_color>"green"</off_color>
</led>
</hbox>
</vbox>
Last edit: 24 Mar 2012 17:39 by ArcEye.
24 Mar 2012 17:33 - 24 Mar 2012 17:40 #18761
by ArcEye
PS
A more normal way of activating LEDs is by linking pyvcp LEDs to signals, such as coolant activation.
For instance:
Using the same .xml to create a LED , pyvcp.led1
In the main .hal file, mist coolant relay is linked to iocontrol
net coolant-mist <= iocontrol.0.coolant-mist => parport.0.pin-17-out (pin 17 is coolant relay)
In the custom_postgui.hal file, the signal coolant-mist is linked to pyvcp.led1
net coolant-mist => pyvcp.led1
Then every time coolant-mist is active (TRUE) the LED turns red.
Hopefully between the 2 examples your query is answered
For instance:
Last edit: 24 Mar 2012 17:40 by ArcEye.
24 Mar 2012 19:32 #18762
by lorisdag
Hi guys, I feel tomorrow .. thank you very much
hello loris
hello loris
26 Mar 2012 08:20 #18800
by lorisdag
hi, thanks for everything perfect collaboration
loris:)
loris:)
