initval is not working in scale
19 Jun 2012 19:46 #21118
by babis
initval is not working in scale was created by babis
Hi
I use this line in my pyvcp:
<scale halpin="heater1.set-sv" initval="10" min_="300" max_="0" orient="vertical" width="25" length="500" />
Whatever the initval i use the scale always start at 300 or whatever is the min value.
If i reverse the order of min and max then it works ok. Is any way to force the initial value to apply?
Thank you
Charalampos Alexopoulos
Thank you
19 Jun 2012 19:55 #21119
by BigJohnT
Replied by BigJohnT on topic Re:initval is not working in scale
I would assume that min must be less than the initial value and max must be more than the initial value to work. You seem to have it backwards...
19 Jun 2012 20:22 #21121
by babis
Replied by babis on topic Re:initval is not working in scale
Thank you for your answer. You are right, after some search i found in the [pyvcp_widgets.py] file in the [pyvcp_scale] class this code fragment:
if initval < min_:
self.value=min_
elif initval > max_:
self.value=max_
else:
self.value=initval
I change it to:
if max_ > min_:
if initval < min_:
self.value=min_
self.value=max_
else:
self.value=initval
else:
if initval > min_:
self.value=min_
elif initval < max_:
self.value=max_
else:
self.value=initval
Now it working both ways. It will be nice if it is added to the next release. When you use verical scale is more user friendly to have the lower value in the bottom.
Regards
if initval < min_:
self.value=min_
self.value=max_
else:
self.value=initval
I change it to:
if max_ > min_:
if initval < min_:
self.value=min_
self.value=max_
else:
self.value=initval
else:
if initval > min_:
self.value=min_
self.value=max_
else:
self.value=initval
Regards
19 Jun 2012 20:48 #21122
by BigJohnT
Makes sense to me...
Time to create page: 0.057 seconds
