fix a connection between pyvcp and ngc
06 Mar 2013 03:42 #30937
by mfoster
Replied by mfoster on topic Re:fix a connection between pyvcp and ngc
Andy,
I have downloaded and installed the buttons on your bodgesoc site, and they should be very helpful. Ive got the buttons showing up on the UI now, and I understand most of the process, but the buttons don't find the ngc files. Where should I put them, and how do I link to them?
Malcolm
Malcolm
06 Mar 2013 04:05 #30938
You need this in the INI
www.bodgesoc.org/lathe/Lathe.ini
And then the ngc files with the subroutines in need to be wherever the SUBROUTINE_PATH points:
www.linuxcnc.org/docs/html/config/ini_co...b_rs274ngc_section_a
(actually, mine live in the place pointed to by [DISPLAY]PROGRAM_PATH because I started off with a much older version of LinuxCNC. )
Replied by andypugh on topic Re:fix a connection between pyvcp and ngc
06 Mar 2013 04:33 #30940
by mfoster
That did it - thanks - I didn't have the subroutine path
Time to create page: 0.207 seconds
