disable pin
- slingerben
05 Apr 2010 13:08 #2518
by slingerben
disable pin was created by slingerben
I'm new to pyvcp. Does someone knows how the disable pin works?
I know that the basic code is <disable_pin>true</disable_pin>. First i tried to put de name of the disable pin between the tags. Then i put the link in the custom_ postgui.hal. Then when I run emc2 (axis), i get a error saying that "-disable_pin" is a unknown option.
Already, thanks for the help.
05 Apr 2010 17:28 - 05 Apr 2010 17:39 #2519
Replied by cmorley on topic Re:disable pin
<led>
<disablepin>True</disablepin>
</led>
try that
Seems I intended the key word to be disable_pin but used disablepin instead.
led , rect led, labels and buttons can use disable pins for your info.
</led>
try that
Last edit: 05 Apr 2010 17:39 by cmorley.
- slingerben
05 Apr 2010 18:04 #2521
by slingerben
Replied by slingerben on topic Re:disable pin
That doesn't seem to work either. If a run it in emc2, and look with the halmeter. There's still no disable pin availeble.
I also tried to put true between the "" tags.
05 Apr 2010 18:07 #2522
But there was no error?
what version on EMC are you using?
please post your pyvcp file
- slingerben
05 Apr 2010 18:24 - 05 Apr 2010 18:30 #2523
by slingerben
no, there was no error.
The version i am using is 2.3.4.
Thanks for the help.
file --> it's a part
<?xml version='1.0' encoding='UTF-8'?>
<pyvcp>
Include your PyVCP panel here.
The contents of this file will not be overwritten when you run stepconf again.
<label>
<text>"Spindel snelheid:"</text>
</label>
<meter>
<halpin>"spindle-rpm"</halpin>
<text>"Speed"</text>
<subtext>"RPM"</subtext>
<size>200</size>
<min_>0</min_>
<max_>3000</max_>
<majorscale>500</majorscale>
<minorscale>100</minorscale>
</meter>
<label>
<text>"Extra controls:"</text>
</label>
<tabs>
<names>["Controls", "Assen", "Tool-selc","Tool-chg"]</names>
<!--Firts tab-->
<vbox>
<checkbutton>
<halpin>"klauw-check"</halpin>
<text>"Klauw openen"</text>
</checkbutton>
<hbox>
<!-- Here is the problem!-->
<led>
<halpin>"led-kap"</halpin>
<on_color>"green"</on_color>
<off_color>"red"</off_color>
<disablepin>"True"</disablepin>
</led>
<label>
<text>"Sensor kap"</text>
</label>
</hbox>
<checkbutton>
<halpin>"led-on"</halpin>
<text>"led aan"</text>
</checkbutton>
<led>
<halpin>"led-start"</halpin>
</led>
<button>
<halpin>"tool-klaar"</halpin>
<text>"tool klaar"</text>
</button>
</vbox>
<pyvcp>
<label>
</label>
<meter>
<size>200</size>
<min_>0</min_>
<max_>3000</max_>
</meter>
<label>
</label>
<tabs>
<!--Firts tab-->
<vbox>
<checkbutton>
</checkbutton>
<hbox>
<led>
</led>
<label>
</label>
</hbox>
<checkbutton>
</checkbutton>
<led>
</led>
<button>
</button>
</vbox>
Last edit: 05 Apr 2010 18:30 by slingerben.
05 Apr 2010 18:46 #2524
disable pins are only avaiable in emc 2.4
Strange there was no error
- slingerben
05 Apr 2010 18:47 #2525
by slingerben
Alright, still thanks for the quick replies.
05 Apr 2010 18:54 #2526
if it is really important to you you can try out emc 2.4 (pre-release)
this is how:
emc2-buildbot.colorado.edu/~buildmaster/
by the way don't use quotes around True for disable pins
Sorry it didn't work out
Chris
this is how:
Chris
05 Apr 2010 19:35 #2527
for anyone reading this I fixed 2.4 to use the correct spelling.
<disable_pin>True</disable_pin>
06 Apr 2010 10:41 #2529
by BigJohnT
Replied by BigJohnT on topic Re:disable pin
Chris,
Thanks for fixing that.
Time to create page: 0.489 seconds
