cycle timer not working
27 Nov 2012 09:10 - 27 Nov 2012 09:11 #26970
by jlviloria
cycle timer not working was created by jlviloria
copying the cycle timer John (hardinge),
displayed but does not work stays at zero when I run the program?
that can be bad.
in HAL:
loadrt time
addf time.0 servo-thread
in post-gui.hal
net run-status => time.0.start
net cycle-seconds pyvcp.time-seconds <= time.0.seconds
net cycle-minutes pyvcp.time-minutes <= time.0.minutes
net cycle-hours pyvcp.time-hours <= time.0.hours
in xml file
-<hbox>
-<label>
<text>"Cycle Time"</text>
<font>("Helvetica",14)</font>
</label>
-<u32> <halpin>"time-hours"</halpin>
<format>"2d"</format>
</u32>
-<label>
<text>":"</text>
</label>
-<u32>
<halpin>"time-minutes"</halpin>
</u32>
-<label>
<text>":"</text>
</label>
-<u32>
<halpin>"time-seconds"</halpin>
</u32>
</hbox>
that can be bad.
in HAL:
loadrt time
in post-gui.hal
in xml file
-<hbox>
-<label>
</label>
</u32>
-<label>
<text>":"</text>
</label>
-<u32>
</u32>
-<label>
<text>":"</text>
</label>
-<u32>
</u32>
</hbox>
Last edit: 27 Nov 2012 09:11 by jlviloria.
27 Nov 2012 11:17 #26972
Replied by cmorley on topic cycle timer not working
You must connect run-status signal to something.
Is it connected to something?
In these cases running halmeter to do your own investigating helps a lot.
You can narrow the problrm down that way - and it makes it easier for us to help you.
Chris M
Chris M
27 Nov 2012 13:52 #26973
by awallin
Replied by awallin on topic cycle timer not working
the documentation over here could be improved
linuxcnc.org/docs/2.5/html/man/man9/time.9.html
the correct pin name is halui.program.is-running
"net run-status halui.program.is-running"
I'm not sure how one is supposed to reset the "time" component. Or is it just meant to count the sum total hours the machine has been running (since the start of linuxcnc). I would guess it resets when you restart linuxcnc or reboot the machine.
27 Nov 2012 19:54 - 27 Nov 2012 20:04 #26984
by BigJohnT
Replied by BigJohnT on topic cycle timer not working
It resets each time you start it. It times how long the part took to make.
I thought the documentation was 1000 times better than most man pages as it actually has some what needs to be improved?
Have you tested it with halui.program.is-running?
I did fix an error in the description from an early assumption of how it should be used but after testing on a live machine found the error in my assumption.
Last edit: 27 Nov 2012 20:04 by BigJohnT.
27 Nov 2012 19:55 - 27 Nov 2012 20:07 #26985
by BigJohnT
Have you examined the run-status signal to see that it is on when you expect it to be on?
Did you add time.0 to the servo thread?
Last edit: 27 Nov 2012 20:07 by BigJohnT.
28 Nov 2012 00:58 #27003
by awallin
says "halui.is-running", but the correct pin name is "halui.program.is-running"
I'm not sure what "Time Converter" refers to. What is converted to what? "Timer" is perhaps better.
Does the time component run forever once it has seen true on the start-pin? Or does it stop when the start-pin goes false?
If the latter, I suggest "enable" as a better name for the pin that is now named "start"
Also the man-page is somewhat inconsistent in that at the top it suggests "halui.program.is-running" as a source for start.
But further down what is actually used in the example is halui.program.is-idle followed by a not-component.
I would be happy to contribute to the manuals/man-pages, but I would need clear and simple instructions how it's done (e.g. on the wiki). Last time I tried I apparently patched the wrong branch and my patch got lost.
this pageI thought the documentation was 1000 times better than most man pages as it actually has some what needs to be improved?
28 Nov 2012 01:22 #27006
by BigJohnT
Read the man page again, I edited it this morning to fix the is-running error.
Time Converter converts seconds to minutes, hours, seconds. It is not just a timer.
Can't change names now...
When it is on it times, on the rising edge it resets the timer.
28 Nov 2012 04:11 #27014
by jlviloria
Replied by jlviloria on topic cycle timer not working
John,
works perfect.
only one detail in loadrt not.0 think should go loadrt not count = N
Thanks John my machine is producing parts I will upload videos and photos so you can see how it looks
works perfect.
28 Nov 2012 05:10 #27019
by BigJohnT
Sweet! I love it when a plan come together.
28 Nov 2012 09:39 #27030
Replied by andypugh on topic cycle timer not working
Great! I have occasionally been worried that it never would. I am really quite relieved that we didn't encourage you into a too-hard project.my machine is producing parts
The following user(s) said Thank You: jlviloria
