cycle timer not working
09 Jul 2013 22:20 #36450 by rmattioda
Replied by rmattioda on topic cycle timer not working
I am still struggling with this one.
I have the items on my screen but when I add:
loadrt time
loadrt not
addf time.0 servo-thread
addf not.0 servo-thread
net prog-running not.0.in <= halui.program.is-idle
net cycle-timer time.0.start <= not.0.out
net cycle-seconds pyvcp.time-seconds <= time.0.seconds
net cycle-minutes pyvcp.time-minutes <= time.0.minutes
net cycle-hours pyvcp.time-hours <= time.0.hours
it will not allow EMC2 to open.
all my .hal-.ini is at this link
www.linuxcnc.org/media/kunena/attachment...615/linuxcncpost.txt
your help is appreciated
09 Jul 2013 22:32 #36451 by andypugh
Replied by andypugh on topic cycle timer not working
LinuxCNC will tell you _why_ it didn't start, if you read the error report.
My first guess would be that you have put the new stuff in the wrong HAL file, it needs to be in the postgui halfile, or there is no PyVCP to link to.
09 Jul 2013 22:33 #36452 by BigJohnT
Replied by BigJohnT on topic cycle timer not working
Attach the output from dmesg after clearing it and trying to run your configuration.
www.linuxcnc.org/docs/html/common/Linux_...tml#_bootup_messages
JT
09 Jul 2013 22:51 - 09 Jul 2013 22:55 #36453 by rmattioda
Andy,
when i look at the report is says, cannot load time loadrt time. what do you think?
also i did post this in my postgui file
Last edit: 09 Jul 2013 22:55 by rmattioda.
09 Jul 2013 23:09 #36454 by ArcEye
Replied by ArcEye on topic cycle timer not working
My SWAG (as JT would say)
What version of Linuxcnc are you running?
time was not in 2.4.x
09 Jul 2013 23:45 #36456 by rmattioda
problem answered, I am running 2.4.6
09 Jul 2013 23:57 #36457 by BigJohnT
You can add a component if you don't care to upgrade.
JT
10 Jul 2013 01:41 #36462 by rmattioda
you mean add the timer in 2.4.6? if so how?
10 Jul 2013 03:30 #36467 by BigJohnT
Yes, just add it to 2.4 if you don't wish to upgrade. IMHO I would upgrade to 2.5.2.
Copy the following to time.comp
component time "Time on in Hours, Minutes, Seconds";
description
Time
When the time.N.start bit goes true the cycle timer resets and starts
to time until time.N.start goes false. If you connect time.N.start to
halui.is-running as a cycle timer it will reset during a pause. See
the example connections below to keep the timer timing during a pause.
Time returns the hours, minutes, and seconds that time.N.start is true.
Sample pyVCP code to display the hours:minutes:seconds.
<pyvcp>
  <hbox>
  <label>
    <text>"Cycle Time"</text>
    <font>("Helvetica",14)</font>
  </label>
  <u32>
      <halpin>"time-hours"</halpin>
      <format>"2d"</format>
  </u32>
  <label>
    <text>":"</text>
  </label>
  <u32>
      <halpin>"time-minutes"</halpin>
  </u32>
  <label>
    <text>":"</text>
  </label>
  <u32>
      <halpin>"time-seconds"</halpin>
  </u32>
  </hbox>
</pyvcp>
In your post-gui.hal file you might use the following to connect it up
 loadrt time
 loadrt not
author "John Thornton";
license "GPL";
// Input Pins
pin in bit start "Timer On";
// Output Pins
pin out u32 seconds "Seconds";
pin out u32 minutes "Minutes";
pin out u32 hours "Hours";
// Global Variables
variable double totalnsec;
variable int old_start;
function _;
#include "rtapi_math.h"
FUNCTION(_) {
    __u32 totalseconds;
    if(start && !old_start) totalnsec = 0;
    if(start){
    totalnsec = totalnsec + period;
    totalseconds = totalnsec * 0.000000001;
    seconds = totalseconds % 60;
	minutes = (totalseconds / 60) % 60;
	hours = (totalseconds / 3600);
	old_start = start;
Follow the instructions to install dev here
www.linuxcnc.org/docs/html/hal/comp.html#_installing
Then open a terminal and say
sudo comp --install time.comp
If you create the file in your home directory when you open a terminal you won't have to change directories to install the component.
JT
10 Jul 2013 05:22 #36471 by rmattioda
I have a probotix and they said they haven't made any with that version and dis advised me too.
what do you think?
Time to create page: 0.079 seconds
