Time machining widget problem with linuxcnc 2.5.4
27 May 2014 21:50 #47399 by eng_wmw
Hi all
After updating linuxcnc to latest version 2.5.4 , the time widget working great but program execution stop suddenly
after removing time widget and test the same G-code it run without any problem
Note: time widget didn't make this problem with linuxcnc 2.5.3 only with latest version 2.5.4
Please help , files attached
Thanks..
File Name: custom_postgui.hal
File Size:0 KB
File Name: custompanel.xml
File Size:1 KB
27 May 2014 22:24 #47403 by ArcEye
Hi
I cannot see anything wrong with your files, the hal file is a direct lift from the component header.
Seems unlikely anything was changed, but I will have a look at the code in a bit
In the interim, there is another way to display and use a timer in pyVCP, it is just undocumented.
see this post
www.linuxcnc.org/index.php/english/forum...-functionality#47339
27 May 2014 22:32 #47404 by ArcEye
Just checked and the time component in both 2.5.3 and 2.5.4 is byte identical
I would suggest the problem must be somewhere else.
