Map a keyboard key to a PyVCP button
- JoeHildreth
- Thank you received: 14
28 Apr 2015 05:46 #58175
by JoeHildreth
Map a keyboard key to a PyVCP button was created by JoeHildreth
I looked through the PyVCP forum and didn't see anything related, but is it possible to map a PyVCP button to a keyboard button? I am wanting to make a pendant from a keyboard controller and would like to be able to do a touchoff from the pendant.
Thanks,
Joe
Thanks,
Joe
28 Apr 2015 10:06 #58179
Replied by cmorley on topic Map a keyboard key to a PyVCP button
Surprisingly difficult.
What version of linuxcnc are you using?
What screen are you using (eg AXIS) ?
If you are using a separate keyboard for the pendant (ie two keyboard controllers) ?
I think gladeVCP will be what you need to use - it can call MDI commands fairly directly.
You could use pyvcp with a classicladder program for touch off (it has been done), but that doesn't get you the keyboard connection.
Do you just want the keyboard connection and not really need the on screen button?
Chris M
Chris M
28 Apr 2015 13:08 - 28 Apr 2015 18:53 #58180
by ArcEye
Replied by ArcEye on topic Map a keyboard key to a PyVCP button
Hi
Have a look at my Axis modifications
www.mgware.co.uk
Axis Modifications > User Keys
I wrote this specifically for a HID pendant, to map commands to number keys, but it works off the keyboard numbers too.
They are here too
www.linuxcnc.org/index.php/english/forum...is-user-defined-keys
I never did bother trying to get them accepted in Linuxcnc, but these and all the other modifications have been in Machinekit for some time.
www.mgware.co.uk
They are here too
Last edit: 28 Apr 2015 18:53 by ArcEye.
- JoeHildreth
29 Apr 2015 00:46 #58201
by JoeHildreth
Replied by JoeHildreth on topic Map a keyboard key to a PyVCP button
Chris,
I am running LinuxCNC 2.6.7 with the AXIS GUI.
I was intending of using a second keyboard conroller, hacking it to make the pendant. I will take a look at galdeVCP. I suppose I don't really need the on screen button, it would be easier (read I am being lazy) to use a pendant.
Joe
Joe
- JoeHildreth
29 Apr 2015 00:47 #58202
by JoeHildreth
ArcEye,
I will take a look at it. Thanks for the Link and info.
Joe
Joe
Time to create page: 0.231 seconds
