G-Code Generator
26 Aug 2015 18:55 #61807
by BigJohnT
Did you following the guidelines from here?
linuxcnc.org/index.php/english/forum/36-...-this-before-posting
JT
Replied by BigJohnT on topic G-Code Generator
I can't get it to attach ???
JT
26 Aug 2015 19:00 #61808
by BigJohnT
Can you split out the code lines in question? There are no line numbers in Kunena.
JT
JT
26 Aug 2015 22:38 - 26 Aug 2015 22:40 #61811
by mmt
Replied by mmt on topic G-Code Generator
I wasn't aware of the limits on file formats.
Here are the lines of code and I will also attempt to attach it here.
thanks again
# Create Buttons
self.DoItButton = Button(self.EntryFrame, text='Recalculate', command=self.DoIt)
self.DoItButton.grid(row=12, column=4)
self.SendToAxis = Button(self.EntryFrame, text='Send To Axis', command=self.SendButton)
self.SendToAxis.grid(row=12, column=5)
if IN_AXIS:
self.quitButton = Button(self, text='Write to AXIS and Quit', command=self.WriteToAxis)
else:
self.quitButton = Button(self, text='Quit', command=self.quit)
self.quitButton.grid(row=16, column=1)
self.quit()
def CopyClipboard(self):
self.clipboard_clear()
for line in self.gcode:
self.clipboard_append(line + '\n')
def SendButton(self, obj, data=None):
sys.stdout.write(line + '\n')
os.system("temp.ngc")
def WriteToAxis(self):
self.quit()
def DoIt(self):
for seg in self.segID:
self.PreviewCanvas.delete(seg)
self.segID = []
self.gcode = []
thanks again
# Create Buttons
if IN_AXIS:
else:
self.quit()
self.quit()
def DoIt(self):
self.segID = []
self.gcode = []
Last edit: 26 Aug 2015 22:40 by mmt.
27 Aug 2015 00:11 #61815
by BigJohnT
The Tkinter self.quit() is what exits the program.
You should be using Gtk and Glade IMHO.
JT
JT
01 Sep 2015 04:35 #61958
by mmt
Can it be done with Tkinter ?
01 Sep 2015 04:51 - 01 Sep 2015 04:56 #61959
by BigJohnT
JT
What is "it"?Can it be done with Tkinter ?
JT
Last edit: 01 Sep 2015 04:56 by BigJohnT.
01 Sep 2015 05:19 #61960
by mmt
send the file to axis and have the gui remain open ?
01 Sep 2015 05:24 #61961
by BigJohnT
Remove the self.quit() if you don't want the program to quit.
JT
JT
01 Sep 2015 21:17 - 01 Sep 2015 21:17 #62000
by mmt
Thanks John but that doesn't work. Any other suggestions?
Last edit: 01 Sep 2015 21:17 by mmt.
Time to create page: 0.071 seconds
