Failure
02 May 2011 08:08 #9532
by Robin
hey guys,
I have a code for activating a electro pneumatic switch
I have this code:
setp parport.0.pin-14-out-invert 1
net klauw-op pyvcp.klauw-open => flipflop.0.set
net prog-run halui.program.is-running => and2.1.in0
net klauw-cl pyvcp.klauw-sluiten => and2.1.in1
net and-uit and2.1.out => halui.program.optional-stop.on
net klauw-cl => flipflop.0.reset
net klauw-uit flipflop.0.out => parport.0.pin-14-out
net klauw-uit => pyvcp.led-klauw
It worked untill i upgraded my emc2 version.
the problem is when i test the pins and flipflops with the software it should be working
But in real the output always stays high, i've already tested all components it all works.
I can open close it manually but not automated.
Can someone help me please
Greetings Robin
I have this code:
Greetings Robin
02 May 2011 11:54 #9536
by BigJohnT
Replied by BigJohnT on topic Re:Failure
What did you upgrade from and to?
02 May 2011 12:04 #9538
by Robin
Replied by Robin on topic Re:Failure
Woeps
from 2.3.5 to 2.4.6
from 2.3.5 to 2.4.6
02 May 2011 12:11 #9539
by BigJohnT
Did you follow the instructions here for upgrading?
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?UpdatingTo2.4
02 May 2011 12:14 #9540
by Robin
jep
02 May 2011 14:29 #9543
by BigJohnT
Looks ok to me but I've not tested it. Can you switch to a different parallel port pin and test it there. If the logic worked before it should still work.
