Bash doesn't recognize comp
- ldmarsaglia
26 Oct 2009 17:00 #1037
by ldmarsaglia
Bash doesn't recognize comp was created by ldmarsaglia
Hello again, i'm having troubles with comp, i've already used it in another machine a few months ago but now i can't make it work.
When i execute the command comp in the console, my system doesn't recognize it as a bash command, and it says that maybe the program comp is in any of the following packages:
nmh
mailutils-mh
I donwloaded the packages (the one called nmh had an error with a .deb file) and the problem persists.
I think the main problem is that i need to donwload some packages but since the ones that apt recomends don't work well i was thinking in asking you guys to guide me.
Well thanks in advance as always
Best regards.
Leonardo.
nmh
mailutils-mh
Best regards.
Leonardo.
26 Oct 2009 21:08 #1038
by alex_joni
Replied by alex_joni on topic Re:Bash doesn't recognize comp
You need to install emc2-dev, that package contains comp.
Regards,
Alex
Regards,
Alex
- ldmarsaglia
27 Oct 2009 00:19 #1041
by ldmarsaglia
Replied by ldmarsaglia on topic Re:Bash doesn't recognize comp
Thank you very much alex, i installed the package and worked.
Best regards.
Leonardo.
Best regards.
Leonardo.
Time to create page: 0.075 seconds
