Newbie: Spindle control 0-10, PWM, ???
19 Dec 2009 05:15 #1358
by dmerriman
Newbie: Spindle control 0-10, PWM, ??? was created by dmerriman
I'm looking at putting together my own little system (hobbyist level), and can't see any kind of control over spindle other that 0-10V and PWM -- or am I missing something?
I've got a number of stepper motors, and it wouldn't be any big deal for me to gear one of them down to some arbitrary number of minutes (or even seconds) of angle per step; is there any reason I can't/shouldn't do this?
19 Dec 2009 05:27 #1359
by dmerriman
Replied by dmerriman on topic Re:Newbie: Spindle control 0-10, PWM, ???
Let me add that what I want to do is have a CNC that can do X/Y/Z, with the capability of serving double-duty as a CNC lathe (which is what I'm calling the spindle).
19 Dec 2009 05:30 #1360
Replied by cmorley on topic Re:Newbie: Spindle control 0-10, PWM, ???
The component stepgen can be used to control steppers in velocity mode instead of position mode.
Velocity mode commands the stepper motor to rotate at a constant speed instead of a position.
I don't know of any sample HAL files to follow. Stepconf won't set this up for you.
You could use Stepconf to create a configuration then hack the HAL file to add a step generator for the spindle.
19 Dec 2009 05:43 #1361
by dmerriman
For the interface between EMC2 and the motors, I'll be hacking together a microcontroller-based interface, so I can do pretty much whatever needs to be done (I'm a computer geek taking a walk on the wild side ).
If I'm understanding you correctly, stepgen will put out some command telling the spindle how fast to go; it would be up to me to figure out how to "translate" that command (absolute speed? value from 0 to some maximum?) into the appropriate stepper speed to produce the specified RPM.
19 Dec 2009 12:30 #1362
by BigJohnT
Replied by BigJohnT on topic Re:Newbie: Spindle control 0-10, PWM, ???
Stepgen puts out a step pulse and a direction pin.
www.linuxcnc.org/docview/html//hal_rtcomps.html
19 Dec 2009 15:49 #1363
by dmerriman
Okay, I'm tracking with you now.
Thanks very much for your help!
