show port-stat
11 Jan 2010 21:09 #1493
by gironymo
show port-stat was created by gironymo
hi there,
i hope my post is right here ...
so, i'm new in using emc and i tried to use it with my isel-milling-machine today.
i created a new controller-board because the isel has an own uC-board with an interpreter. the code is like g-code, but not the same.
ok, i'm able to move the axis of the machine, but i don't know which port is used for spindle or hoover. i don't know which input is used for emergency-stop ...
so, is ther any posibility to monitor the single pins of the lpt-port(s) and set the single ports manually?
sorry, i'm also new in using linux ...
greetings from austria
markus
markus
12 Jan 2010 12:54 #1500
by BigJohnT
Replied by BigJohnT on topic Re:show port-stat
Open the Hal Configuration and look in the Pins section.
www.linuxcnc.org/docview/html//hal_basic_hal.html#r1_4
12 Jan 2010 21:27 #1504
by gironymo
Replied by gironymo on topic Re:show port-stat
thanks a lot ... thats what i need.
Time to create page: 0.064 seconds
